Adjusting JL Drag Link to Straighten Steering Wheel
sacourtney07
Sean
San Diego
2018 Wrangler Unlimited Sport
I couldn’t find the info anywhere online so I figured I would help fellow NooB owners out like me.
If your steering wheel is off center, loosen this nut with a 15 mm wrench, then adjust the knurled adjuster either direction. You can have somebody sit at the wheel and watch it, or continuously get up to check. Take a ride and see if you like the new steering wheel adjustment.
The torque value for the adjustment nut is 34 ft-lbs.
https://[Banned Site]/showthread.ph...ER-Reference-Guide&p=12885&posted=1#post12885
californiajeeping
JLUR
When I adjust the steering wheel to center it, it looks great in the garage. But then it is off again while test driving. I've tried 6 times and can't get it exactly right. Is there any trick to make sure the tires are perfectly straight besides eyeballing it when it is parked before making the adjustment? Like somehow using a level on one of the front tires? The fenders are curved so makes it difficult to know if the front wheels are straight before adjusting the knurled adjuster.
Vinny2002
Vincent
Hartford, CT
Jeep Wrangler Rubicon 2020
Should the jeep be in Neutral?
Vinny2002
Vincent
Hartford, CT
thx. i went wrong way first time. made the ESC light come on. I am centered now. will that go off on next drive? thx
Walter_Mustang
Adam
Oklahoma
2021 Jeep JL Willys Sport 4 door
I just lifted my Jeep and my steering wheel is slightly to the left. Loosened the nut and clamp and could not get the bar to adjust. It would not move at all. 2021 Jeep Willys 1200 miles
MarkY3130
Denver
2019 JLUR
If you’ve got the bolt loosened up and can’t get the knurled adjuster to spin, then you could try a pry bar to help spread the ears of the clamp a bit. Wouldn’t need much
LittleDog
New Jersey
2020 Sahara JLU
My weenie arms alone couldn't break the adjuster loose the first time either. Just use a big tongue and groove wrench.
Gibson Leatherworks
