Adding stock rear USB and AC ports
Scarabmike
Miguel
Jacksonville, FL
2018 JLU
I know this has been covered in the past with aftermarket options. But has anyone installed the stock center console car and connectors? I was doing some research, and found these part numbers.
Media Hub USB Port - Mopar (68271567AB)
Jumper Wiring - Mopar (68350769AD)
Jeep Wrangler JL Adding stock rear USB and AC ports {filename}
Console End Cap - Mopar (6BW38TX7AB)
What else would I need?
exilepa
Ohio
2019 JLU Sport S
How much is the cost with just those parts?
exilepa
Ohio
2019 JLU Sport S
I think the biggest question is are the pigtails already there that are needed to plug into
BLACKMOAB
2018 Black JLU MOAB, 2021 Black Lexus GX 460
I’d think the tough part would be getting the air back there. I doubt the duct work is already in place.
am1978
MD
2018 JLU Sahara Bright White, 2018 JLU Sahara HellaYella
‘Merica
FCA should have put USB or USB-C in the top of the dash for phone docking without excessive wires.
scottedontknow
PA
89 YJ, 95 YJ, 2019 JLU x2
Did you ever have any luck with this?
PLDJ1000
Pascal
Lancaster County, Pennsylvania
2021 Wrangler Unlimited
Was wondering if anyone else had luck with this "OEM" install?
I have it on my to-do list for the spring... wanted to get some miles on the Jeep before I started tearing everything apart.
WhereRU_A-A-Ron
Aaron
Arkansas
2021 Unlimited Willys, 2015 Toyota Sienna XLE
Restaurant Manager
This may or may not be helpful so take it for what you will: For the amount of money you seemingly would need to spend on this project just for parts, you could get a pretty good portable power bank. Hide it under the backseat and take it out/with you whenever you need to. Plus it’ll have more charging options. We have a Goal Zero Yeti 200X that we use just for this purpose. Just my two cents.
PLDJ1000
Pascal
Yes, you got a great point. I'm gonna take the time to look at the power banks before I shovel money into an OEM retro-fit. I did see another members 12v Socket install also after posting this, and i may consider that route also... Just looking for some power in the back seat for the kid.
