Adding DRL to a JL Sport Altitude
recartier
Robert
middletown , ct
jeep sport
Ok I messed up when I took delivery on my Atlitude. It didnt have the LED group and as such no DRL
Is there any way to add these or is not worth effort since the harness and controls are missing
Thanks
mwilk012
2018 Ocean Blue JLU Rubicon
Service
Don't worry, you didn't make a mistake. There is no getting factory DRL's on a sport wiring harness.
To be clear, I'm saying that even if you had ordered the "LED Headlamp and Fog Lamp Group" you would not have DRL's.
recartier
recartier
Robert
middletown , ct
jeep sport
So on Sport Ulitimate without the LED Group .. I am a done.
Sounds like they only come on Willy's , Rubicon and Sahara ?
mwilk012
Service
Willys is a sport. Just Sahara and Rubicon based trims.
Gregj
Greg
West Texas
JLU Rubicon, JLU Sport, JTuRD
Thanks
You can get DRL’s to work on a Sport. You won’t have a dedicated DRL it will use the turn signals as DRL’s. See this thread in the lighting section. @jludave is the guy who has lots of experience doing this.
https://www.jlwranglerforums.com/forum/threads/drl-dropout.47142/
You will need to download the JScan app and get a bypass cable and a OBD2 dongle.
Reach out to Dave, I’m sure he can give you info on getting it done.
Gregj
Gregj
Greg
West Texas
which requires a fender swap
Not true. You can change the settings in the BCM to make your turn signals the DRL, then add switchback LED’s and have what you want. White DRL’s and amber turn signals.
Check the thread I linked to for more information
Gregj
Oracle, a sponsor here, has the led’s you need among many other sources
recartier
recartier
Robert
middletown , ct
jeep sport
does it also require a new harness.. I also dont see a control in the Uconnect Lighting options so I guess it would work but not be controlled ?
Thanks everyone
Gregj
Greg
West Texas
If you swap the flares, the new harness is part of the the light assembly. You will need to program the BCM with a programmer, either Tazer, JScan or Flashcal, there may be others. Flare swap is very easy. I have done it on my Sport S.
Gregj
