Those won’t fit a Sport flare. Hope they have them fixed with the new revision. The previous version was NOT plug and play!
Yea, that's another option. Thanks for the clarification.Not true. You can change the settings in the BCM to make your turn signals the DRL, then add switchback LED’s and have what you want. White DRL’s and amber turn signals.
Check the thread I linked to for more information
Gregj
Oracle, a sponsor here, has the led’s you need among many other sources
I have added the Kiwi Master LED with drl to my sport altitudeOk I messed up when I took delivery on my Atlitude. It didnt have the LED group and as such no DRL
Is there any way to add these or is not worth effort since the harness and controls are missing
Thanks
SO when running the lights (Parking Lights) or With the headlights they are white and when you activate the turn signal they flash amber. I saw that in the video .. just want to be sure that I wasnt mistaken.. thanks again for the postI installed a set of these on my Sport S. I now have DRL (white turn signal light), no reflash or additional harness necessary. It does require a resistor install which is easy. Also can be installed just popping one plastic pin (don't need to do two plus the bolts).
https://headlightrevolution.com/2018-jeep-wrangler-jl-front-turn-signal-kit/
Correct. They are as in the pic for running, flash amber when using either turn signal or emergency blinkers. Mine is a 2020 Sport S, ymmv (don't think the Altitude package would make a difference - maybe give them a call).SO when running the lights (Parking Lights) or With the headlights they are white and when you activate the turn signal they flash amber. I saw that in the video .. just want to be sure that I wasnt mistaken.. thanks again for the post
