JCae2798
My plan was to use the one channel with the passive crossovers that Focal provides. This way* i use 2 channels for each side. I was going to bridge the other two for the sub. Down the line if i wanted to i could potentially run coaxials to the rear and add a 2nd amp for the sub only as i did in my old system.And you want to amp the Focal's?
I know going active would be ideal but this has worked for me in the past and I just want cleaner sound at a little bit of a higher volume then what i have now with factory alpine...
To recap i will be using the JL VX400/4i amp for this setup.
EDIT:
Honestly i probably would have used my 2nd amp for the sub alone and could have had all 4 channels available for the fronts, but with the 4xe, space is limited and i want to keep the trunk space looking stock for when i have the top down/side panel windows off.
