I just got a 22 JLU Willys Sport and definitely interested in adding the power locks. Following and researching more…
I’ve been reading thru a couple of these threads and it seems no one ever reports that they actually got any of this to work, other than the beginning of this one where the front doors were working and sort of ended there. Im in same situation. 2022 JLU sport. Would love to add OEM power locks rather than an after market system.
it's manual latch on the base sport etc, you need this Part Number: 68282968ABI just picked up the wiring harness last night and plan to install it today. Once you have power locks enabled by the dealer, you need to replace the wiring harness as I’m told the lock that comes with the Jeep for the tailgate is a power lock latch.
Quick question if you see this. Can I add the OEM remote start kit without OEM power locks. I purchased the a1 electric kit for the locks. Since the door lock signal wires already exist on the Sport, I’m thinking the remote start kit will work after the dealer enables it.I bought the remote start kit and they had to turn on power locks for it to work. Maybe see if they will do it if you buy the remote start.
please explain. Do you have remote locks. I looked idatasrart up and they have very little info on what they offer and how it works.i used an Idatastart remote start, it connects to the can bus. it activated power locks and alarm. i didnt need to go to the dealer. Also their remote has a better range than OEM
i got mine from crutchfieldplease explain. Do you have remote locks. I looked idatasrart up and they have very little info on what they offer and how it works.
Here are some notes that I have preened from TechAuthority. Hope you all find it helpful.
1) RF Hub or Remote Frequency Hub is the main player for RKE (Remote Keyless Entry). It is is pretty much the primary device for all KeyFob/Wireless activities as all devices such as Remote Start and Proximity Entry must pass thru it to in order to work as the RF Hub is what talks to the BCM. Here is verbatim from T/A "The RF-Hub, along with the BCM, is the primary RKE system controller.... The RF-Hub marries itself to the BCM and PCM with an Immobilizer Access Code using a high security encryption system called Advanced Encryption Standard (AES) at first key on in the assembly plant."
So going by T/A, no RF Hub module = no RKE. Since it ties to the BCM and is "married" to it you must have the dealer program it or have the ability to modify/ replace a BCM to pair with the RF Hub module. The remote start module is not required for RKE and from what I have read the remote start kit is just an antennae module that connects to the RF Hub. So for manual transmission owners (the few and the proud), if you can get your dealer to pair an RF Hub module to your system then the rest looks to be gravy.
2) Telematics Module is part of the UConnect system. To have full control of the RKE system such as being able to go into the settings on your display and finding the door lock options your UConnect/Telematics system must have those features programmed. It also allows you as the owner to program your own Key Fobs. So the dealer was correct in providing this as a part that is needed but if you dont care about the UConnect controls from the dash display it should be able to bypass it which is good since that part ranges from $600-900 and I imagine that is because of the Uconnect 3/4/5 variations.
Based on the above I am going to go back to my dealer and ask them to order me the RF Hub Module and in the same conversation get their acknowledgement that they can do the programming for me. Then I will check to the UConnect to see if the system reads the new module. if not, I am not going worry and move to installing one door with power locks to confirm, or not, that the setup works. If it doesn't I may be out 500-600 dollars but my curiosity on this topic will be answered.
Richard did you ever get this to work?I don't have RKE but I have a RF hub. In the base models that have remotes, with no buttons, the RF hub is the passthrough and communications to the BCM for it. All Jeep Wranglers with push to start have to have an RF Hub. Even though the remote has no buttons, its still using the RF Hub to let the push to start to start the jeep. When your battery is dead in your RF remote, you press the key fob against the push to start button because it reads the RFID chip inside the remote to allow you to start with a dead remote. RKE is only for locking and unlocking the doors.
Randy did you get your power locks installed and working and what about the remote start? I do not live too far from you as I have a lot of relatives where you are.Quick question if you see this. Can I add the OEM remote start kit without OEM power locks. I purchased the a1 electric kit for the locks. Since the door lock signal wires already exist on the Sport, I’m thinking the remote start kit will work after the dealer enables it.
Yes, installed A1 Electric kit. Works fine on all 5 doors. Only downside is having an extra remote, the remote is tiny though. Haven’t tried to add remote start. A1 kit is well done, not to difficult just time consuming.Randy did you get your power locks installed and working and what about the remote start? I do not live too far from you as I have a lot of relatives where you are.
