Acetone and HotHead Headliners - Warning! - and make fun of me if you want...
Asterix2112
Vienna, Va
Wrangler 4xe
This is a warning for anyone who is looking to install HotHead headliners (other headliners may be similar)
Got my brand-new 4xe yesterday. today I went to install my HotHead headliners that I had bought a while back. The instructions say to scuff the surfaces with sandpaper, and then clean with acetone. That's all it says. So I scuffed with sandpaper, and cleaned with acetone. Now, of course, by sanding some fine white dust settled on other plastic pieces of the Jeep and such. So I figure I have a towel full of a cleaner, I'll just wipe it all down. DON'T DO THAT. Acetone will ruin, I mean totally ruin any of the dark plastic pieces on the Jeep that it touches. And now I have several parts of my Jeep that are ruined...
Now obviously I am an idiot to not know this intuitively, because when I called HotHead and spoke to Mark (the owner), who was very nice, to ask him why he didn't put a simple warning to make sure that you do not touch any of the other plastic parts with the acetone, he said this is the first time in 10 years anyone has ever complained to him about it. So I guess even though I'm a college educated computer security expert, it seems I am also an idiot and I should've known this, so please all the people who want to make fun of me go ahead. But if it stops just one person from making the same mistake that I made and stops them from ruining their brand-new Jeep than it's worth it.
I'm going to look to see about replacing a few pieces of plastic on my Jeep. And Mark from HotHead offered to help make it right, so I don't want to badmouth HotHead in any way (the headliners look great and are easy to install notwithstanding this issue), and if really no one has ever complained in 10 years than maybe I really just am and idiot do not know this!
jludave
The Isle of Long
tehkayd
Kris
SLC Utah
2021 JLUR Sting-Gray
I just installed my Headliners but I took off the top entirely to install them. I also did not know the use of Acetone but after I looked it up, I chose not to use Acetone instead after I vacuum and clean up manually. Sorry to hear about your troubles.
InTooJeep
Montague, MI
'21 JLUR, '07 Trailblazer
I commend you for owning up to your mistake though. Tough lesson to learn. All too often, people this day and age are quick to blame others for their ignorance. So I give you my respect and empathy. Too bad for your brand new Jeep. Must suck to suck :facepalm:
The Last Cowboy
San Antonio, TX
2020 JL Willys 2 door
Wandering Vaquero
90% alcohol that you can buy at the drug store will also work just as well.
Roverhi
Peter
Kailua-Kona, HI
1970 Series 2 88
When I read the installation instructions that called for doing the install in place I said NO WAY. I've been involved with fiberglass in boats forever and you do everything you can to mitigate the spread of the dust created when you sand or grind it. Sanding that roof on the truck is just asking for a lifetime of itching. If I get the headliners, will pull the top and do it upside down with gravity and containment of the dust handled.
4x4PNW
Paul
Seattle
Toyota Seqouia, Wrangler Rubicon 4xe on order
Thank you for posting this. You likely saved me and others from making a similar mistake.
Chupacabra
Littleton, CO
2021 JLU
You don't have to sand that much. I did mine in place and it was no big deal to vacuum up what little bit there was. No itching so far :)
Jeepr
Gary
Alabama
'20 2dr Rubicon
I have seen others restore aged or exposed black plastic trim pieces with a heat gun, may be worth a try.
flot
South Florida
2020 JLUR
1) That sucks.
2) Yes you should have known this.
I AM surprised that the directions say to sand and acetone the top while it's installed, as that sounds like a miserable way to do it, but I think this one is on you. As above you could try heat (gently) or a product like mother's like back-to-black depending on what exactly has happened. Are we talking about plastic that has lost its shine, or plastic pieces where the outer coating has been removed?
Mike921921
FL
2020 Gladiator Altitude
With a black interior, I was way too OCD to install mine without first removing the top(s). Kudos to you for owning up and potentially saving someone else the same headache.
calemasters
Allen
Springfield, Mo.
2021 Rubicon Unlimited, & Escalade
Retired Mechanical Engineer
Sorry this happen to your Jeep. We all make mistakes. I have done plenty of stupid stuff. Sometimes I find a way out of my mistakes, sometimes not. But now I am glad I ordered the factory headliner. Maybe you can replace the worst of the parts.
BillWorkbench
Bill
Las Vegas
www.youtube.com
2020 JL 2-door Sport S (Stock)
IT person
When I sanded my top, I used a wet towel with the sandpaper and the dust was minimal. I cleaned with 90% IPA.
The only issue I have is the smell, I am going on three weeks now.
Other than the smell, which is hopefully going away, they are great.
Chocolate Thunder
I installed HotHeads with the top in place (except freedom panels) and dust wasn’t an issue at all. You’re only supposed to scuff the surface a bit, not sand it. This creates minimal dust. As Bill mentioned above, a wet towel will eliminate the minimal dust created.
Blade1668
Darrell
N Alabama
91MJ,90XJ,91XJ,05,LJ,05JT
Don't worry everyone screws up at least you manned up with it. Acetone is some nasty stuff with plastic. If you do any welding you will want a gallon or so of it around to clean metal but damn sure make it's evaporated away before welding or cutting.
Now don't mix bleach and ammonia cleaning something.😉
Rock Krawler
