Sold: Washington Accutune Fox 2.0 Performance Series 1.5-4″ Lift, LSC Adjuster
Kevin Mojito
Kevin Mojito
Kevin
Washington
2019 JLUR Moijto 2005 TJ AEV Hemi
Hey Rob
Nice, you went with King's. I really like the color and looks of the King. Good to hear Accutune valving worked out.
Did you get the adjustable king's?
I have the 95/120 spring, it's soft for sure. How's the 110/120 spring for street. I have been thinking of going to the 110/120 2" spring, as the 95/120 needs a 1" spacer to flatten out my setup.
RubiRob
Rob
Hampshire, IL
www.instagram.com
Jeep
Hey Rob
No I didn’t. If you read the blog on accutunes website, they admit on there that with the king compression adjusters there’s not as much variance as the fox shocks. Plus I figured if I’m getting them completely valved they should be good to go without needing a change. The springs are great, I think synergy says it’s only 5-10% stiffer than stock. I called them and spoke to Dave when I ordered. I specifically asked if I would notice the rate difference between mopar spring and theirs and he said “[email protected]&$ no.” To that same end, I asked accutune if I would need to revalve my shocks if I moved to a set of Metalcloak springs and they said no as well, as the valving would not be affected by a slight change in spring rate.
moodywizard
Lyle
2019 JLUR
The falcons probably seems stiff due to them being digressive valving, known to be stiff on the initial strokes which makes it seem rude stiff on the street.
Glad to hear the Kings are working good with accutune valving. I’m still running the fox 2.0 off the shelf with evo 3.5 lift. Seems like a dump truck at time over pot holes haha
RubiRob
Rob
Hampshire, IL
www.instagram.com
Jeep
Well, to be frank they don’t seem stiff they are stiff. Plenty of teraflex employees I’ve heard run 2dr falcons on their 4 doors because they’re stiff. On bigger bumps the digressive works better but on the day to day, they’re frequently jarring. I ran the sp2s on the softest setting and 26psi on the tires. With my Kings the tires are at 31psi and it handles the daily drives noticeably better.
moodywizard
Lyle
2019 JLUR
Haha no doubt, was just stating probably due to the digressive vs progressive valving.
moodywizard
Lyle
2019 JLUR
Sorry if I came off harsh wasn’t my intention. Either way, very happy with my king custom valved shocks
No worries, didn’t take as harsh just passionate which is understandable. I would get the Kings but fox seems to have a little bit more travel. Haven’t really decided to pursue anything yet because I may go long arm in the future. Been thinking about going with the mc 6 packs short term if anything because of the travel they provide. Yes I know the horror stories of them leaking etc but can’t beat the travel they provide for short arms.
RubiRob
Rob
Hampshire, IL
www.instagram.com
Jeep
They do, that’s understandable to go with fox in that case. Good luck!
Motor City Aftermarket
