Accidental audio improvement with dash speakers and Alpine system
thundermuffin
Todd
Prague, CZ
2018 JLUR Soft top
Just replaced my corner dash speakers with the infinities- only took 1.5 Jack & cokes, a right angle philips #2, a trim popper, and a Dremel - sounds fantastic!
Fire Burns
Fire
CA
Was this replacing Alpines, and would you definitely say the sound is significantly improved, enough to justify the cost? I'm still on the fence, even after reading this entire thread.
Jebiruph
Jerry
Iowa
2018 JLU, 2019 KL, 2020 JT
I would be curious to know whether or not everyone is installing the included capacitors with the new speakers.
thundermuffin
Todd
Prague, CZ
2018 JLUR Soft top
Yeah, replacing the alpines. Significantly improved, well worth the price.
thundermuffin
Todd
Prague, CZ
2018 JLUR Soft top
I did not use the big capacitors included with the speakers. There were some smaller ones already soldered on to the speakers, I left those in place.
Jebiruph
Jerry
Iowa
I was referring to the big capacitors.
thundermuffin
Todd
Prague, CZ
2018 JLUR Soft top
DogsOnTheRun
Georgia
2019 Sahara
The capacitors supplied cause a "pop-pop", when you shut down your Jeep, so I took them out after going to the trouble of soldering them in.
The improvement is great, especially in open top situations, where you pretty much could not even hear the Alpine factory units.
Joker4L
Anthony
New York
2024 Jeep Wrangler JL 4XE High Altitude
Military
If you read through the thread you will see that installing the large capacitor introduces a Electrical popping noise Through the speakers every time you shut off or turn on the vehicle e
Jebiruph
Jerry
Iowa
Not everyone that installs the large capacitors experiences the electrical popping. It looks like two of you did when I searched the thread for the term "pop", so I was interested in knowing if others had the issue or did not have the issue. Maybe it's just an issue with the Alpine system, they do not cause popping on my non-Alpine system.
7474
OH
2019 Wrangler Unlimited Sport Altitude
Definitely agree with the improvement in open top situations.
Replaced the sound bar's also and noticed an additional improvement over just the front dash.
I used the Infinity 3022's the discontinued previous version of the 32s. Found them for $42 a pair on Amazon.
RSK
SC
2016 Wrangler 2015 Renegade 2020 Gladiator Rubicon
Senior Director of Engineering & Facilities
So what is the consensus between these two below? Both specs are 75W. I’ve always been a fan of Infinity speakers for outdoor use and own 3 pairs, but never tried them in the car. Also read good things about JL C2’s as well. These dash speaker pods (link below) are coming out soon. I believe they might be a big improvement based on direction alone. They will fit the C2’s. Just curious if anyone has tried the C2’s as well?
https://tlcautotruck.com/jeep-wrangler-jl-dash-speaker-pods/
JL Audio C2-350x 3.5-Inch 2 Way Speakers 75W
Or
Infinity REF3022CFX 3.5" 75W
StrikeZ
TJ
Maryland
2018 Jeep Wrangler Rubicon Unlimited
Or
You could buy that dash adapter and put the Infinity speakers in it.
The Infinity speakers are $70. I wonder how the sound will balance going from OEM mid-range to a two way?
StrikeZ
TJ
Maryland
It does, though you wouldn't know to look at those speakers.
I just replied to another in this thread, I guess going from mid-range to two way would be different. I was thinking of changing mine and like Infinity.
I would likely change the roll bar tweeters to maintain balance.
