A/C works with the switch off
KeithF
Central Va
2021 Wrangler 80th Anniversary
I have a 2021 with the 8.4” Uconnect and the automatic temperature control. I normally drive home from work with the ac off and windows open, but today it was just too hot. I had the ac on and everything works/cools really good. When i turned up my driveway I turned the ac switch off (indicator light off in the button)but cold air kept blowing even after you expect the last of the cold from the evaporator to be gone. When I parked I opened the hood to see if the compressor was still engaged and it was. Fan speed was on 5, auto was turned off , ac switch was off and the temperature was on Lo.
I noticed if I turned the fan speed to 3 or below the ac/compressor cuts off and blows unconditioned air, turn fan speed to 4 or above and ac turns back on even with the ac button turned off.
I’ve never had an automatic climate system like this before and dont know if this is normal operation.
TJHUB
Terry
WI
2021 JLU Sport Altitude
I don't know about the fan settings, but I too noticed my '21 will blow A/C in auto mode with the A/C off. I find it strange that it does that, but I've just decided it must be how it works in auto mode.
yuriy
Yuriy
Ohio
2021 rubicon 392
Were you able to find out if that’s normal?
Wbino
NJ
2021 Wrangler JL H.A. -- 1999 SLK 230
Just noticed this yesterday.....will investigate..
GATORB8
CLT NC
21 JLURe
I'd have to play with it, but I think auto mode over rides the A/C button.
In order to actually have manual control, you have to get out of Auto:
Jeep Wrangler JL A/C works with the switch off 1657724356707
mwilk012
2018 Ocean Blue JLU Rubicon
Service
So it turns out on the JL, you can’t turn the compressor completely off. The software will turn it on whether you want it to or not.
KeithF
Central Va
Mine is consistent in that if the outside temp is hot and I have the fan on "4" the ac turns on when I put it in park, not if the fan is on "3". I dont really trust the dealer to give a good answer as they brush you off unless its broken, so I'm taking it as this is normal after my 2nd summer
Canucklesammich
2022 JLR
My guess: if it's on auto, it's gonna try to maintain a set temperature (determined by the red/blue knob settings). The fact that it kept blowing cold when the knob was on "low" seems to indicate that.
Chupacabra
Greenville, SC
2021 JLU
Yes, when the system is in AUTO mode, the AC light does not light up even if AC is being called upon. At least that's how mine works. If you are not in Auto mode, then the AC button seems to work as expected to enage/disengage AC and it lights up accordingly.
mwilk012
Service
It doesn’t. If you have the temp set low, Auto turned off, and A/C turned off, the compressor may still kick on.
John VonJeep
Middle of Nowhere
Many
Correct. Mine does this too.
It doesn’t make any sense to me, but could it be related to cooling for the eTorque system? It seems to happen only with the engine needs cooling and the variable fan is on high under the hood.
Chupacabra
Greenville, SC
2021 JLU
When you say "set low" do you mean where the HVAC display actually says LO and not just a low temperature setting like 64 degrees or something?
I'll have to test that on mine as I don't know that I have ever manually set mine to LO on the screen and see if it seems to do that for me. I do not have eTorque if It makes any difference...
KeithF
Central Va
I have the 2.0 Turbo, no e-torque. I always have the temp set at LO on the screen as my wife requires a/c when shes with me and the a/c is turned on, I dont usually have a/c turned on when I'm by myself tho. If the fan setting is on 4 or higher the a/c will kick on when put in park and the outside temps are hot/high. If the fan is set on 3 or below it does not.
Chupacabra
Greenville, SC
2021 JLU
I did not try the highest fan speed, but at mid-speed on LO, my AC definitely does not run with the AC button turned off. I will try it again by turning the fan all the way up to see if that finally engages it without the AC button being on next time I drive it :)
