DW10
For sale is a fine example of a well cared for 4 door Jeep Cherokee Laredo.
92' Cherokee Laredo with the reliable 4.0 Inline 6 - manual 5SP .
Stock except items below including suspension refresh, wheels/tires and pioneer radio.
270k on body with NEW engine only 5k miles old. No rust. Zero problems.
Paint and body is remarkable. Sunroof. No leaks. No roof rust. Exterior/Interior is exceptional with usual wear.
Asking 10,000 OBO.
OBO is because some planned items are not fully completed and I'd discount accordingly.
NEW ENGINE:
- Work performed by NT Machine Shop Langley BC 1/2020.
- Hot tanked block, head, intake manifold.
- Block & head magnafluxed for cracks - all good.
- Block bored .30 over stock.
- Crank re-ground to .10" & balanced and polished
- New cam bearings
- New Valve Springs,
- All gaskets are FelPro
OTHER:
New timing chain and gear set.
New Oil Pump and Oil Pressure sending unit
Throttle body cleaned (62mm TB planned in future)
New 4-hole Fuel Injectors - new spark plugs
New Temp Sensor and Air Filter
New Fan Belt
New Clutch Master Cylinder, Clutch Line, Clutch Flex Plate, clutch disc, slave cylinder and throwout bearing
High Flow CAT and New Magnaflow Muffler
New CCV/fresh air inlet valves pcv vales on top of valve cover
new high pressure steering hose
New heater control switch
Transfer case fluid change
Radiator Flush
New Motor Mounts
Royal purple 5W-30W
New Starter 3/2020
New Headlights / Brake light Bulbs 3/2020
New Front Brake Pads 2/2020
New rear brake drums 8/2021
SUSPENSION: ~2.5 - 3" Lift 8/2021
- New Old Man Emu Front Springs #2930 coils with 3/4 spacer
- New Old Man Emu Rear Leaf Springs (Full set CS033RB)
- New Old Man Emu Nitrocharger Sport Front/Rear Shocks (60052L/60053L)
- Using the L version one could add another 1-1.5" in height and not need to change shocks
- Can remove one of the rear leaf springs for a softer ride and lower rear height ~1/2" +
5 MOAB Rubicon Wheels with 245/75/16 Cooper Tires (have original set of 5 wheels/tires)
Tow Package and wired for 7 and 4 pin connector
Raptor Liner on front/rear bumpers and side cladding.
Planning to have the front seats re-foamed and covered
Crack on left side of windshield and small rock chip in lower middle
(planned to replace in future)
Jeep drives smooth and true and the more you load it up the better the Old Man Emu suspension feels.
Asking 10,000 OBO.
NEW ENGINE:
- New cam bearings
OTHER:
New Fan Belt
Radiator Flush
New Motor Mounts
Royal purple 5W-30W
New Starter 3/2020
