roaniecowpony
We'll see soon enough if I need the clearance. I'm dropping my JLUR at a friend's shop Monday for a MetalCloak 3.5" Gamechanger, 37s, skids, gears, etc, which requires a driveshaft change. If I do need more clearance, I'll machine an aluminum plate with cross drilled passage and O-ring seals to retain the original flow path.I swapped mine and have been fine since. I believe OP abandoned that plugging/delete route and has such done the same
I don't like the idea of the heater, since I live in an arid climate where most of my use is in hot weather as high as triple digits.
Meanwhile, I've been monitoring trans fluid temps. Seems to run around 200F just driving normally in 85F weather (with the OE 2018 thermostat/heater assy).
