7'' Oracle LED Headlights- Blowout Sale!
ORACLElights
Peak Sponsor (Level 2)
Metairie, LA
www.oraclelights.com
2019 Jeep Wrangler JL
Automotive LED Manufacturing
ORACLE 7" HIGH POWERED LED HEADLIGHTS (PAIR) - BLACK BEZEL - NO HALO - USED
Part Number: 5769-504
Certifications: CAPA, DOT, SAE
Regular Price: $263.35
Sale Price: $99
Fits Models:
1945-1985 CJ
1996-2006 TJ
2007-2018 JK
2018-2020 JL (*Brackets needed sold separate)
*USED
*Minor scratches and road wear
*Includes H13/H4 adapters
*No brackets included
*No Warranty
The Ultimate LED replacement headlight option for any vehicle with 7” Sealed Beam lamps. The rugged design is perfect for your Jeep Wrangler, Off-Road Vehicle, Buggies, or Classic Car/ Truck. Installation is very easy with the included H4 and H13 “Plug and Play” connectors.
Latest Product Improvement
• Improvements in brightness and reliability by adding a constant current LED driver to the main circuit board inside of the lamp to control the halos.
• NEW! No need for Anti-Flicker Wiring Adapters- The new SMART Integrated Can-Bus system automatically adjusts- preventing flicker issues.
• Increased Reliability- By conditioning the power going into the LEDs this prevents degradation which can shorten the overall lifespan of the product.
• Wider Input Voltage Range- The new SMD Halos can operate on a very wide voltage range from 12V-24V so that voltage spike can not damage the LEDs.
• Brighter LED Halos- by moving the heat load of the resistors off the PCB we are able to increase the number of LEDs on the circuit board without thermal issues.
• LED chips upgraded from a Cree LED to a Phillips Luxeon ZES chip.They deliver a very high efficacy 130LM/W ratio while having lower thermal output.
Product Features: (Per Light)
• Low Beam Wattage: 30W Normal/36W Max
• Low Beam Lumens: 2200 Lumens/3600 Raw Lumens
• High Beam Wattage: 40W Normal/48W Max
• High Beam Lumens: 3600 Lumens/4800 Raw Lumens
• Color Temperature: 6000K (Cool White Color)
• Input Voltage of Light: 12-24V DC
• Input Voltage of Halo (If Included): 12V DC
• Current Draw: 2.50 Amps @ 12V DC / 1.30 Amps @ 24V DC
• Premium Performance Phillips Luxeon ZES LEDs
• Die-Cast Housing with Corrosion Resistant Coating
• Heavy Duty Solid State Electronics
• Hard-coated Polycarbonate Lens
• Wide Beam Pattern with Sharp Cut-Off Line
• Easy Plug & Play Installation
• DOT and SAE Certified
Wiring for Halos:
• Red Wire is (+) the positive wire
• Yellow Wire is (-) the negative wire
greenvillebigwheels
Upstate SC
2019 Wrangler Unlimited Sport
Engineer
Hello,
I called you guys to buy a set of these today and was told you would send a paypal invoice but I never got it. Can you share an order link? Thanks.
ORACLElights
ORACLElights
Metairie, LA
Hello,
Sorry! Busy days here at Oracle! Which is awesome! Sending invoice now.
rdw799
DACULA, GA
2019 JLU
Im interested as well. Also, how much are the brackets that have to be purchased separately?
greenvillebigwheels
Upstate SC
Engineer
I would just call oracle. I was going to buy them but you have to pay for shipping, buy the brackets for 90, and the wiring adapters for 30 or 40. It all added up to over 250 bucks for used headlights with no warranty or you can buy the whole jl kit new from cj pony parts for 280 after using a 20% off code thats easy to find. I ended up springing for the oculus lights using that 20% off
