eLECTRICON
Guest
Looks like you got the double ball base for the driver side - how did yours fit? I got the single ball base and I needed to shave mine down with a dremel to get it to sit flush in the dash.
Mine fit. Not sure the problem your having? What do you mean flush with the dash? Are you not using the rubber tray? You have to trim the ends off the tray.Looks like you got the double ball base for the driver side - how did yours fit? I got the single ball base and I needed to shave mine down with a dremel to get it to sit flush in the dash.
I reached out to 67D and they offered a replacement but functionally mine works just fine, I was just curious if anyone else had run into that issue.
I took the tray out, and my mount wouldn't sit where it was supposed to. It was too big, and sat at an angle like the red line shows. I needed to shave some material off of the bottom edge of the mount itself to get it to fit correctly. It seems like this may be an isolated issue since 67D said nobody else had reported any fitment issues. Either way it was a small adjustment and it works fine now. I cut my rubber tray to fit and reinstalled it after the 67D base was installed.Mine fit. Not sure the problem your having? What do you mean flush with the dash? Are you not using the rubber tray? You have to trim the ends off the tray.
