58Willys
- Geoff
- Jan 2, 2022
- Western Washington
- 2018 JL Sport
Plug color looks good, but the gaps seems really large.
There's this: https://www.jlwranglerforums.com/forum/threads/torque-values-for-jeep-jl-wrangler.17791/#post-518090Anyone have the spark plug torque spec handy or know where to find it for the 2.0? I don’t have the FSM.
I didn’t think that thread had engine specs but I should’ve looked. Thanks!There's this: https://www.jlwranglerforums.com/forum/threads/torque-values-for-jeep-jl-wrangler.17791/#post-518090
Denotes 13in/ft but I generally go a smidge past finger tight or until the socket wrench stops then a slight tap past. Not very tight at all. I change all 8 plugs on my 5L V8 Porsche, same thing. Better for it to be snug than accidentally stripping threads on the head.
I just have to post this... I had a new 1983 Porsche 944... I serviced the baby myself. I had 550,000 miles on her before she went to the Porsche junk yard.. She was a great car, ran forever.... almost. I think it was 30 years.When I was growing up, my dad had a Porsche Audi repair shop. So, I worked on tons of 928's when I was a teenager and into my early 20's. Those things were built like a tank. Then there were the failures. The ones with the twin disk clutch (which always went bad back in the day before they updated them). I could change out the complete assembly in 40 minutes. Then people that were not careful with the older ones, would tear out the reverse lockout and bang it into reverse when going out of first. Thus you had to take out that beast of a transmission. Then when they had dual A/C, they leaked freon like crazy. I got good at taking the interior out and crimping on new hoses to the hard lines.
The highest mileage 928 we seen was a 1979 that had 450K on it. we only replaced the head gaskets at 350K. Rest of the engine was original. Back then the rear muffler was $1500 (this would be in 1985 dollars). So I remember cutting it off and sticking on a piece of 3" pipe instead. The owner liked the sound and thus it was that way until it met it's maker when it was in a flood. Thus, totaled and done for.
I will tell you this, when new, people that were Corvette owners, were the ones that bought 928's. It was leaps and bounds beyond what a Corvette was at the time and they wanted a V8.
I always wanted a 928 but I have decided that it'll be an e92M3 instead. It reminds me of a 928, but newer.
944's paid for my way through college due to the number of broken timing belts, broken balance shaft belts, leaking front end oil seals, snapped off cams, oil in the coolant and the best, 944 Turbo clutches. When a 944 came in on a hook, you knew it was a broken timing belt.I just have to post this... I had a new 1983 Porsche 944... I serviced the baby myself. I had 550,000 miles on her before she went to the Porsche junk yard.. She was a great car, ran forever.... almost. I think it was 30 years.
Original engine and transmission. The clutch was replaced once at 90k miles, but then lasted the remaining 450,000 miles. Proving if a Porsche (maybe any car) is driven correctly, a clutch can last the life of a car. Also, original brake calipers, original fuel injection parts. Cheapest regular gas I could find.
You got some carbon build-up for sure.Just replaced the plugs after about 60,500mi and used suggested factory plugs. Changing them out is easy for 1, 3 and 4....just a 10mm bolt for the coil and a 5/8" deep socket with a 6" extension to unseat and then used a telescopic magnet tool to remove. Getting the second cylinder ignition coil (front to back of engine is 1-4?) is a little tight with the diverter valve especially if you have a DV+ installed. Had to remove some of the sensor connectors without breaking the tabs and wiggle it out.
One this that was concerning was after removing each plug there was black soot flakes that came out from the cylinder. See how dark the threads are. The past 15,000mi have been fairly short distance trips (<5mi) of less than 20min back and forth. Camera makes the plug look a little darker than it actually is, slightly more brownish than dark.
If anyone is interested in what 2.0 2018 plugs look like at about 60,000mi which is the change interval per Jeep.
Upgrades:
GFB DV+
Mishimoto IC pipe
Mishimoto CAI
EDIT+
Plugs
NGK IR ILZKR7G
https://www.allmoparparts.com/sku/68292346aa.html
I have had a few Porsches in my time. Last one a 944 turbo I kept for 26 years before trading it in on a mb. It had 175 000 miles. Did not want to get rid of it but it out lived the Porsche mechanics at the dealer and they refused to work on it any more. Loved that car and it would go a lot faster than advertised.I just have to post this... I had a new 1983 Porsche 944... I serviced the baby myself. I had 550,000 miles on her before she went to the Porsche junk yard.. She was a great car, ran forever.... almost. I think it was 30 years.
I used to race a 1986 944T starting in 1987. One of the two Porsche made to meet the $29,500 maximum price for a car to run in SCCA SSGT class. It was delete option along with roll up windows, no sunroof, no AC and no power steering. Plus no undercoat. Back then in Showroom Stock, it was a game of cheating and not get caught.I have had a few Porsches in my time. Last one a 944 turbo I kept for 26 years before trading it in on a mb. It had 175 000 miles. Did not want to get rid of it but it out lived the Porsche mechanics at the dealer and they refused to work on it any more. Loved that car and it would go a lot faster than advertised.
