500 Mile Break in Oil change caused issues
gsbrockman
Greg
Sand Gap, KY
2023 Dodge Challenger Scat Pack Plus A8 & F8 Green
Owner / Operator Brockman Hauling, LLC
Yea I’m hoping he didn’t say anything about the oil but the fact he said they sent off the oil for analysis tells me he already did. Hopefully they don’t try to pin that on you even if it is completely unrelated just to get out of a warranty claim
It wouldn’t be a true Stellantis warranty claim.
If the oil analysis comes back as ATF or some other hodgepodge of fluids....it will then become an insurance claim with his insurance company, plain and simple.
In the end.....I’ll bet a lot of warranty claims, both valid and invalid, typically result in higher vehicle prices which are ultimately passed on to the new vehicle purchaser.
BullMoose1776
Bull
South Texas
Project Manager
All speculative ideas he had aside, nobody should be penalized for buying the correct factory recommended oil from a reputable store and doing an oil change on their own vehicle, nor should that vehicle catastrophically fail from something so simple as an oil change. I hope they don't go down that road, unless they truly do find like, used ATF in there or something instead of oil, or a 10mm socket in the bottom of the pan.
That's where I keep all of my 10mm sockets, so they don't wander off.
blnewt
New Mexico
Just ask @cosine he knows!
The fit alongside the oil filter, and easy to get to just by removing the cap :)
SparkyIBEW
Gary
Idaho
2022 Unlimited XR Rubicon
My jeep is somewhere between Toledo and Nampa Idaho right now. The dealer said Jeeps website was hacked and therefore has no idea where or WTF. I will drop the oil after 100 miles then at 500 miles and then at 4-5000 thereafter, I don't give a damn otherwise. I've been doing this to several vehicles for many years. For you new Jeep owners doing their own oil changes, give it a try. Wipe and clean your oil pan before dumping the used oil into it and take a good look at all the crap at the bottom of the pan. And that's the obvious particles...... Funny, the oil filter didn't filter that shit out, what a fucking revelation! Now, we don't want all that crap recirculating through our engine now do we? Back in the day we used to run "non detergent" oil to seat the rings, my, how things have changed. Only a fool would change their oil at 10,000 mile intervals. Cheers!
blnewt
New Mexico
I go 6k for each change and do my tire rotations at the same time, seems like a good interval for both. I plan on keeping this thing until my wheels fall off (which will probably be before the Jeeps do lol). I also plan to service my ATF at 60k intervals. It sounds like you plan to have your Jeep for the long haul too!
Like I said in a post above, if it gives you peace of mind, you do you!
Chupacabra
Greenville, SC
2021 JLU
Does car insurance cover things like improper maintenance? I don't think it does, never heard of it being covered anyway. But I could be wrong.
Jim1964
Traveling the US of A
2022 JLUR
Plenty of people have put gasoline in Diesel engines by mistake and reported insurance covered the damage. Comprehensive covers a lot of ground. It’s not like the OP intentionally used incorrect fluid (assuming that it is actually not the right oil).
OBD
Thomas
Arkansas
2021 Jl Wrangler ,2016Soul,Dyna,Sportster,HD
After reading this post,I went straight to the garage and changed my oil and filter. The Jeep had 1057 miles.I had a Mopar filter and container of PP 0-20 synthetic. The drain pug was easy, but the filter removal was nothing like I expected.It was tight pretty much all the way out.I have seen video of folks loosening it and hand spinning it out.No way mine did that.Upon inspection of the filter, it looked great except for one prominent machining chip.IT was aluminum and curled from the machining process for sure. I lubed the o rings up with oil, but the new filter didn't feel much better going in than it did coming out. I'm not sure about the tightness, but it is not leaking. I want to unscrew the filter housing and grease the o rings and threads but not sure if it would start leaking.
SparkyIBEW
Gary
Idaho
Sorry for the rant. By the time I finished reading 8 pages of the above, I was seeing "RED". To each his own, like the man said, peace of mind. It takes all kinds to make this world go 'round, hell, if we all thought the same, the whole population would be driving Jeeps and they'd all be the same color! Back to the important stuff, to the OP, Sorry for drifting off on a tangent. How's that coming along?
OSCAR II
NJ
14 JKF
DONT!
If its not leaking don't worry about it. Its a crappy setup but you don't want to cause problems. Next time, I use oil myself.
  • Like
Reactions: OBD
TCorgard82
TCorgard82
Thor
Minnesota
2022 Wrangler Sport S 2 door, 2014 Ram 1500
Engineering Technician
So word from Dealer, they found metal when they pulled the dipstick not filter as other service advisor said. He told me they have to tear the engine down to see what happened. He stated nothing I did was wrong, I assumed I was putting the correct items in per the label. But he thinks that much metal it might be a manufacture defect. So now still in a holding pattern.
1BadManVan
Darren
Bc Canada
2019 Wrangler JLU Sahara/2018 Durango R/T
Locomotive Engineer
Well that sucks about the motor but it sounds like the dealer will take care of it atleast under warranty if they are staying it’s not fault of yours.
Sorry for such a rough start into ownership, it does happen sometimes on mass produced engines.
John VonJeep
Middle of Nowhere
Many
That’s great to hear. What a relief for you. Please keep us posted on the progress.
