4xe rubicon take offs -> 2018 jlu sport s
Donevan.Ausborn
Donevan
Oahu
2018 Jeep Wrangle JLU Sport S 2.0, 03 VTX 1800 C
Scrolling on Facebook and found 4XE Rubicon takeoffs I was just seeing if they would work on a 2018 JLU sport S, there is a couple 100 lb difference on the 2 and they are a few years apart, tryna lift on a budget and seeing if these 2 are compatible, lmk what y’all got for me.
Shibadog
Bowling Green, Ky
2020 Wrangler Sport S hardtop
What are you talking about? Wheels/tires? Suspension? Or ?. The guys here will be able to give you good advice if you let them know the details
Donevan.Ausborn
Donevan.Ausborn
Donevan
Oahu
My bad I forgot to include that, suspension, coils and shocks, I just put them on and the back seem higher than the front , day pic before, night pic after
Donevan.Ausborn
Donevan.Ausborn
Donevan
Oahu
Jeep Wrangler JL 4xe rubicon take offs -> 2018 jlu sport s 25B3330D-6CB3-4FF3-807E-083BE2BB0347
I will get day pic of after tmro when I have more light
TheBirdie72
Rhode Island
2021 Jeep Wrangler Freedom Edition 2 Door
How is that?!😂
I have a two door sport s freedom edition that I did a rubi 4xe takeoff suspension and 33” Falken tires on. Awesome inexpensive upgrade. Search @blnewt ’s “rubi suspension on 2 door” thread and get all the info you could ever need. 👍
txj2go
DFW
I put Rubicon takeoffs on my Sport and gained 1.5" front and 2" back. This may be somewhat common, I've heard of other people having similar results and adding a small spacer in the front to even it out. You probably need to do something like this.
It might be hard for you to quantify what you need. If you can find a stock Rubicon then take some measurements and compare with yours. I was able to measure from fender down to ground for before and after. You wouldn't be able to do this because Rubicon fenders aren't the same as Sport fenders, you would have to find some other reference point.
Deke
2019 JLU 6.7
I added 1/2" spacers in the front of mine and it leveled it out perfectly.
Donevan.Ausborn
Donevan.Ausborn
Donevan
Oahu
Did it level it out completely to where you add weight in the back and it looks to be sagging?
Deke
2019 JLU 6.7
Yes, I can put a level on my rock rails now and the bubble is centered when I'm parked in my garage. Not sure how accurate that really is but it matches my eyeball.
Jeep Wrangler JL 4xe rubicon take offs -> 2018 jlu sport s Rubi Lift
Donevan.Ausborn
Donevan.Ausborn
Donevan
Oahu
And that’s good enough! Is that a Rino rack on your jeep? If so, what’s it rated for?
Deke
2019 JLU 6.7
It's just a Mopar rack, not sure of the weight limit. I just got it to hold a small canopy.
