4xe Parking/Emergency Brake Extension for Lift/Droop
GATORB8
CLT NC
21 JLURe, 25 HDZR2
This has come up from myself and a couple others within other threads, and I figured it deserves it's own so we can get some visibility and (hopefully) a solution.
The rear parking brake on the 4xe has a slightly different configuration than the standard JL. As in the JL, the parking brake line is not long enough for full droop on longer shocks (somewhere in the 29-30" extended range). In the JL/JLU the parking brake cable can be rerouted under the frame crossmember to allow for additional droop (synergy even makes a bracket to accommodate this). In the 4xe, the tub sheetmetal prevents this from happening since it creates a wall at the front of the crossmember.
Jeep Wrangler JL 4xe Parking/Emergency Brake Extension for Lift/Droop 1644338998890
In order to run full droop on my current setup, I need a solid 2-3" more slack. I've got the wire "bracket" that holds the cable up completely remove (that's what normally goes on the studs you see in the picture.
I've looked for an aftermarket solution, but it doesn't appear to exist (assuming due to the fact that this isn't an issue when the cable are rerouted on the JL). There are aftermarket cables, but they are for the UD60 swap that has the spring assembly at the disks instead of running down the axle.
My best idea so far is to see if JT stock cables would work.
Any ideas? Brainstorming appreciated.
Shasta_Steve
Sacramento
Toyota FJ, F150 Rubicon 4xe
I know mine is tight. I think in the regular JL you route the parking brakes under the crossmember. Not really possible with the 4xe. My Fox shocks are listed at something over 29", and while my brake lines are tight, I can still get to full droop. Of course I had to take them out of the brackets too.
I do agree it would be nice to come up with an after market solution. I was thinking of some way to extend what we already have.
REDSEAL199
Beau
MO
2021 Wrangler Unlimited Highaltitude 4xe
I did not change the routing of the parking brake. I have a forklift lined up for Friday where I will max out flex to see if I have the issue with both the parking brake and the rear passenger side shock clearance. I will keep you posted. The Rocksports are 30" fully extended and 17.7 fully collapsed.
GATORB8
GATORB8
CLT NC
21 JLURe, 25 HDZR2
Awesome. Passenger side was the issue, IIRC. I had the Jeep on jackstands with the axle fully drooped on both sides, so there is a chance with the axle at an angle that it would be a non-issue.
Look forward to your feedback!
GATORB8
GATORB8
CLT NC
21 JLURe, 25 HDZR2
@TeraFlex Just put my order in for the new Parking Brake extension kit (linked above). Said it was backordered when I checked out. Any word on availability?
dcm80401
Golden CO
2022 JLUR 4xe / 2023 JLUR 4xe
I ordered about 5 minutes ago and I didn't see that. However I did order the speaker relocation for the Teraflex carrier last week and it did note that it was on backorder, but it shipped the next day. So we will see.
GATORB8
GATORB8
CLT NC
21 JLURe, 25 HDZR2
Hopefully you didn't beat me to it and get the last one :)
TeraFlex
TeraFlex
Utah
teraflex.com
JL, JT, JK
You guys are sharp eyed! We just released this kit not even a week ago.
It looks like we have all the parts to build the kits on hand, and the kits just need to be assembled. I would put my best guess for ETA about 1-2 weeks out.
GATORB8
GATORB8
CLT NC
21 JLURe, 25 HDZR2
Great! Thanks for the quick reply!
GATORB8
GATORB8
CLT NC
21 JLURe, 25 HDZR2
Pretty quick for a backorder.
5 minute install, 1/2” or 13mm socket and wrench and a pair of channel locks to yank on the parking brake tab.
FYI, the same 13mm wrench works to depress the tabs on the stock fitting holding the line to the axle, makes quick work of it.
Hooking the hook to the tab, then stretching the axle mount in place seemed to be the easiest way to get it back together.
Jeep Wrangler JL 4xe Parking/Emergency Brake Extension for Lift/Droop 07EDA643-0C90-4275-B1F6-EEB100E17233
Jeep Wrangler JL 4xe Parking/Emergency Brake Extension for Lift/Droop 5C108A53-D155-4F7C-9672-331D47DFBAAD
KarlN
Karl
Sparks, NV.
2021 Wrangler Unlimited 4XE
