LeeLand
- Apr 18, 2019
- San Jose CA
- 2018 Jeep JLUR
I recently had a lift kit installed on my 2018 JLUR. During the install process the front passenger ABS (wheel speed) sensor was stretched and damaged. This caused the following warning lights to come on: ABS, Trac Control, 4wd Serv. In researching this problem the simple solution is to replace the wheel speed sensor (Mopar Part #68394210AD). What I discovered is that that part is in scarce supply. The estimated delivery time from Mopar was 14 days and you can't find an after market equivalent anywhere. Although the JK sensor looks identical, it is not and does not work.
So the issue is this, while waiting for the part I have no ABS, Traction Control, and the big one...no 4WD! The wheel speed sensor error triggers a message that says "4wd temporarily unavailable" and lights up the warning light "4wd Serv". If you shift the Jeep into 4H it will not engage and the 4H does NOT light up on the center cluster. If you shift into 4L the gearing in the rear end changes but the TC does not lock and there is no power to the front diff. The front sway bar disconnect, and front and rear locker feature were also disabled. This was upsetting to me, because I desperately wanted to take the jeep out and test out the new lift kit, and didn't want to wait the 14 days for the part to arrive.
The Solution:
I was finally able to shift the jeep into 4H and 4L and use all of the Off Road Features.
In order to override the "4WD SERV" warning I did the following.
1. Put the Jeep in Park and turn the Jeep OFF
2. Shift the 4WD Lever to the 4H position
3. Start the Jeep
4. The Transfer Case should lock and engage the 4H before the computer has a chance to do a system check and discover the error codes. If it is successful the 4H will be lit on the center cluster. (the 4wd Serv light will stay on)
5. All 4H, 4L and all 4WD features will now be available and work normally as long as the Jeep is left running.
6. the ABS and Traction Control will still NOT WORK.
This hack may come in handy if you have a bad sensor on the trail and need 4WD to get home. Please let me know if you have any experience with this issue or any other suggestions. Thanks.
The Solution:
3. Start the Jeep
