Rundeep_32
I have a 2021 gladiator Sport (manual/roll-up windows) and a 2020 Wrangler sport (auto trans, my Son's)
I installed a (new) tazer in each of them that works great with LED lights, etc.
Here in the Boston area, we got a couple of inches of snow and I went to put the Gladiator (after the tazer was installed) into four-wheel-drive and all that happened were the back tires spinning... actually only the right rear a.k.a. one wheel peel lol.
All other features of the tazer appear to be functional on both of the Jeepsā¦ I don't know of anything else that's not working other than the lack of front wheel engagement.
Then I tried my son's (Tazer installed) and had the exact same results - rear-wheel drive only. No any DTC's just the one wheel peel. I know his four-wheel-drive has worked perfectly (before we put the tazer in) because he very recently drove his Wrangler in deep sand at the beach in 4WD
Is there a setting on the tazer that I need to change in order to shift into 4WD? I even tried four wheel low and still it didn't go into 4WD, though oddly, the gearing went into 4WL.
No dash lights or DTCs but the 4WD icon on the dash does illuminate when shifted into 4WD as normal. No blown fuses under the hood.
I find it very odd that both Jeeps lost their front 4WD engagement after installing the tazersā¦ So on both vehicles, we unmarried the tazer then reinstalled the latest firmware and put them back in the Jeeps and nothing changed we then unmarried both again so the computer was down to stock programming and I put my sons Wrangler on jack stands and sure enough, only the rear wheels would spin whether it was in four-wheel-drive or not. So I know something is not working.
Also, we did try four-wheel-drive after the tazer was removed after unmarrying it and plugged into the SWG (both Jeeps)... So as stock as possible.. and the front wheels again did not engage on either vehicle. That's why in my super long text above, I mentioned, perhaps that there was a slight change to the original software, even though it was unmarried, it may have changed some of the programming of the stock software that could not revert back to stock after unmarrying. I not an programmer at all, but it just seems logical.
At this point I can only think that there may have been some leftover tazer programming left in the original software after unmarrying. So even though I think I'm bringing it all the way back to stock software and SGW, something has changed with the stock software that won't allow me to get the front tires engaged.
If you've read this long question I appreciate it and if you have any ideas of what I should do next, that would be great. I suspect that the original Jeep software is probably corrupt and I have to bring it to a Jeep dealer and have them reflash it... The folks over at Z automotive are looking into itā¦ They have great customer service but I'll also take any crowds source at this point... Any ideas? Thank you, Ed
