ColoradoMike
Hahahaha, so, as the OP said in his OP: A lot of really conflicting information!
Indeed. It's my least favorite aspect of my Wrangler. I love it in most ways, but really wish I had the 4H-auto option.You see what I’m getting at?
Maybe there are 2 parts to this answer. Is it safe for your vehicle: Yes as long as you don’t do sharp curves with traction.You see what I’m getting at?
Yeah but the types of turns I’m typically using 4H for are at around 60mph on I70 through vail pass or on roads like highway 40 to steamboat through winter storms - so very slight turns, nothing drastically quickMaybe there are 2 parts to this answer. Is it safe for your vehicle: Yes as long as you don’t do sharp curves with traction.
Is it safe at highway speeds: No, 4wd cannot help you stop any faster in poor traction than 2H and at full highway speed is insufficient to keep you on the road in dynamic conditions. Momentum is too much for 4H to overcome unless speeds are sufficiently slow (aka, not highway).
OK, I want to change my answer. If traction is good enough you're going 60mph, then as others said, it's 2H or AWD, not 4H....at around 60mph on I70 through vail pass or....
If you need 4H, you shouldn’t be going that fast. You will get lucky for a while, but not forever.Yeah but the types of turns I’m typically using 4H for are at around 60mph on I70 through vail pass or on roads like highway 40 to steamboat through winter storms - so very slight turns, nothing drastically quick
I think the issue is for mixed conditions. Sometimes you're going along (often in Colorado) and there has been snow, but this stretch of road is generally dry and 60MPH is PERFECTLY safe... and then all of the sudden, there's been some blowing snow and you need to slow down as you hit the snowy stretch... it sucks if you are in 2WD when this happens, and you need to shift into 4H as you get into the snow, and then you're past the blowing-snow section and back to mostly dry and 60 is safe again.If you need 4H, you shouldn’t be going that fast. You will get lucky for a while, but not forever.
Yeah this is exactly my issue - the conditions vary constantly so it’s often inconvenient to switch from 2 to 4H (so I often just leave it in 4H) - do all rubicons have the AWD function?? And also I’m planning on switching out the axles either way so I don’t think it’ll be too much of an issueI think the issue is for mixed conditions. Sometimes you're going along (often in Colorado) and there has been snow, but this stretch of road is generally dry and 60MPH is PERFECTLY safe... and then all of the sudden, there's been some blowing snow and you need to slow down as you hit the snowy stretch... it sucks if you are in 2WD when this happens, and you need to shift into 4H as you get into the snow, and then you're past the blowing-snow section and back to mostly dry and 60 is safe again.
In an AWD car, these conditions are easy. With Jeep's part-time 4WD system, you are forced to make sub-optimal choices... i.e., driving way slower than you would need to if you were in a Subaru because you're in 2WD, or just constantly shifting back and forth sometimes suddenly and under stress.
That's why the T-cases that have all of the options: 2H, 4H, 4H-auto, and 4-Lo are best, and I wish they were the standard.
OP; it doesn't need to be a 392 t-case; you can order a 4:1 HD full-time sys with the options above for a regular roob and probably a Willys, I imagine. But as for aftermarket retro-fit... I don't know. I think John VanJeep was saying that these t-cases are also paired with different axle joints, etc...
The axle shafts in those equipped with the full time case have cv’s instead of u joints.I think the issue is for mixed conditions. Sometimes you're going along (often in Colorado) and there has been snow, but this stretch of road is generally dry and 60MPH is PERFECTLY safe... and then all of the sudden, there's been some blowing snow and you need to slow down as you hit the snowy stretch... it sucks if you are in 2WD when this happens, and you need to shift into 4H as you get into the snow, and then you're past the blowing-snow section and back to mostly dry and 60 is safe again.
I suppose I view this as part of getting lucky. When I hit patches like that I reduce speed so I can better see them coming even when the road clears back up. If I go a few miles with no more issues, then I’ll speed back up.I think the issue is for mixed conditions. Sometimes you're going along (often in Colorado) and there has been snow, but this stretch of road is generally dry and 60MPH is PERFECTLY safe... and then all of the sudden, there's been some blowing snow and you need to slow down as you hit the snowy stretch... it sucks if you are in 2WD when this happens, and you need to shift into 4H as you get into the snow, and then you're past the blowing-snow section and back to mostly dry and 60 is safe again.
