48v battery overheated
Zuhair Albalushi
Zuhair
Oman
Jeep Wrangler 2020( 3.6l E-torque)
here is a thing I imported my 2020 JLU e-tourqe 3.6l and two months agoI got check engine light it turned out the code was due to overheated battery of 48V. I took to a mechanic he said it’s the auxiliary pump is not working.
So I really want to ask you few questions about this situation now.
-How reliable the 48v battery? And is it made only for cold weather because here in Oman weather most of the time is hot? and is there a way or a program could cooling system of cooling system of 48v battery adapt with Middle East weather
-does the warranty cover the auxiliary pump or I’m no longer under warranty since I imported the car out of US?
Windshieldfarmer
Randy
Wichita, Ks
2015 JKU, 2020 JlU on order
Get your auxiliary pump fixed and you’ll be fine. We have plenty of hot weather in Texas and Arizona; overheated 48v battery packs are uncommon…even in extreme heat.
MtnMadeAdventure
Rob
Maryland
Jeep Wrangler JL unlimited, 2000 XJ
Was there a resolution to this issue? I am having a major charging issue with my JLU 48v battery.
The Last Cowboy
San Antonio, TX
2020 JL Willys 2 door
Wandering Vaquero
Good luck. Advertise them as fitting 2007 and up Wranglers and also advertise by the tire size 245/75/17. Try $250 and see what happens
