4 Lo for downhill; whirring sound the whole way?
JeepScares
Surly ECR
Hi,
We have been driving our new JLU Rubicon 3.6L with automatic transmission for only a short time, and I finally had a chance to try out its 4 Lo setting.
We were descending a set of steep switchbacks so it seemed prudent to utilize the drag of the drive train. We stayed well below 10mph, but the entire time we descended the drive train made a distinct "whirring" sound. It was a high pitched tone that I might associate with dragging the system at a very high rpm.
Later in the afternoon we made a short climb over some rocks and I had occasion to switch back into the 4 Lo setting. When I was actually driving the gearing against the incline it seemed quiet compared to when I has using it to slow the descent.
I am imagining that the extremely low crawl ratio in this new system causes the gears in the transfer case to spin like a gerbil wheel when it is trying to keep the Jeep from careening down a hill.
Is the noise I am hearing a common experience when working your way down a hill in a new JLU?
Thank you.
DWaX
Wilmington, NC
What is the range of the rpms when you begin to hear the sound?
WaX
JeepScares
JeepScares
Surly ECR
  • Thread starter
  • Thread Starter
  • #4
Engine RPM was down near 1000rpm. Basically the engine was at idle and I was tapping and releasing the brake the whole way down.
D60
CO
JL
The planetaries are pretty noisy, yeah
Uhdinator
Maine
2018 JL Sport HT 2.0T Auto, 2003 TJ Rubicon HT
use hill descent feature.
JeepScares
JeepScares
Surly ECR
  • Thread starter
  • Thread Starter
  • #7
Does that feature interact with the transmission in a direct way?
It is my understanding that the hill descent is simply a computer controlled brake by wire system.
I am trying to better understand the what sort of experience to expect with regards to sounds from the drive line, and its components that are new to me.
limeade
Guy
Reno, NV
2018 JLUR, 2019 JLUR
When using engine and gearing (4 low) while descending, you will hear the drivetrain make the "whirring" noise, it's perfectly normal.
The hill descent control feature is very nice and effective, but is even noisier.
All normal sounds while off-roading and using the features of your new jeep.
Arterius2
Jerry
Vancouver, BC
JLU Sahara 2.0L
Were you in manual mode?
If so, That’s the sound of your engine braking noise. Normally when I do this, I can see my RPM shoot up to not-so-fun levels so personally I would avoid doing that on an auto transmission.
If it’s on auto then it must be something else.
And yes hill descent basically activates the brakes for you and could easily overheat them, so I also wouldn’t use it for long descents, I almost lost all my braking power doing this and was scared shitless.
limeade
Guy
Reno, NV
I don't see a problem using it in manual mode. I use manual mode in 4 low all the time. I simply shift up or down to match the speed and to the terrain and traction level and to keep the RPM's at an acceptable level.
Arterius2
Jerry
Vancouver, BC
JLU Sahara 2.0L
Yes, that’s the correct way at it.
But what I’m saying is that if you say left it in first gear in 4LO coming down a steep hill, and didn’t shift up, your RPM will shoot way high and you will hear that loud wheeerrrrring sound OP described. It’s the sound of engine braking excessively.
limeade
Guy
Reno, NV
I see what you're saying and totally agree with that.
JeepScares
JeepScares
Surly ECR
  • Thread starter
  • Thread Starter
  • #13
FWIW, the sound I am trying to describe is not related to the engine spinning at high rpm. The engine never rev'd up to high rpm.
The sound was apparent even when the transmission was in neutral, which is a circumstance that occurred when I shifted into 4 Lo and later when I shifted out of 4 Lo.
The sound was a bright and shiny tone that I never heard on the old rusty beasts I have driven in the past.
Thanks for the suggestions!
Focker
Sacramento, CA
www.ducati.ms
2020 Jeep Rubicon
General Manager
I would bet it was the engine cooling fan, ours runs like crazy when we are crawling off road.
sf5211
Bronx N.Y.
New 2019 JL
Plumber
Just a guess but maybe the torque converter? I don’t go off road so I can’t answer but any manual transmission folks getting that sound?
Morris 4x4 Center
