4 door rubicon suspension on 2 door sport
CorvZ061
Travis
Ga
2020 Wrangler
I’m confused on spring ID’s. A member local to me has rubicon take off springs, shocks, lower control arms, and track bar for $150.
The part that’s confusing to me is spring #’s. The photos he has shows the following springs 657AD and 658AD, as well as 589AA and 590AA, the chart in the sticky says the springs are JLU Sahara if I’m reading it right? The shocks are clearly rubicon red.
My second question has to do with caster, if these are rubicon springs and I get the 1.75-2” lift I’m hoping for, will the rubicon LCA’s correct the caster angle or would I still need the mopar lift LCA’s?
blnewt
New Mexico
Just ask @cosine he knows!
Only the Rubicon springs and Shocks are different than Sports/Saharas. The upper & lower control arms, track bar, drag link, end links are the same on all models.
AFAIK Rubicon 4drs will have springs taller than a 657
CorvZ061
Travis
Ga
2020 Wrangler
the photos he has shows the numbers listed, the other thing noted is they’re from a 4dr rubicon plastic bumper, hardtop,and tow
blnewt
New Mexico
It's quite possible they have a lower number, I'm not up on the full spring range for the Rubicons, does seem a bit on the low side however.
You could always add a spacer to make up some room there if needed.
CorvZ061
Travis
Ga
2020 Wrangler
I may pass on this one, just save up and get the Mopar lift.
