4:88 vs 5:13 gear set
chiggerdude
Brian Head
Bloomington
2018 JLUR and a 2010 JK - 2010 JK Sport
I want to re-gear up from my stock 4:10's. My dilemma is 4:88 or 5:13.
I'm rolling on 37" ridge grappler tires that actually measure 35.77" @ 28psi.
I do trail ride and moderate wheeling, my concern is interstate driving.
Currently I'm taching 1900 rpm at 75 mph. Which of course is on flat highway without any incline.
Even 5th is a struggle to pass anyone if need be... unless I drop to 4th.
I think I'd like to be around 2300 rpm at interstate speeds in 6th. So maybe I'm leaning 5:13.
Is there any downside to going that tall besides the gas mileage?
Any added heat, wear and tear etc?
Thanks in advance for any know-how or expertise.
rustyshakelford
Brett
Navasota, TX
2019 JLUR-8 speed 2020 F-350
Assuming you have a 6 speed like us. 5.13 is the ticket. We’re around 2400-2450 at 70. Combined mileage is 16-17 avg. Does great off road and terrific driving characteristics now.
Brett
chiggerdude
chiggerdude
Brian Head
Bloomington
Brett
Awesome thanks. That’s about what I’m getting currently in 4th. So I’ll get a feel for it.
chevymitchell
Shawn
K-ville, NC
2019 JLUR (Pain Train), 2022 2500 AT4
Avi Engineer
I run 4.88's on 37's. I chose the 4.88 with the 6-spd mainly because I wheel A LOT and I wanted the extra insurance of the thicker pinion. I'm from NC and my Jeep has been to California twice and wheeled everywhere. It's a great combo. The 5.13's will serve you well, too. If you're asking for downsides, the thinner pinion (Dana 44) is the only one I can think of.
unsavory
Jimmy
2022 JLUR XR 2.0T Auto, 2019 JLUR V6 Manual (sold)
I'm on 4.88s with 35s and wouldn't mind going 5.13s with my manual. I'd suggest 5.13s with 37s. You'll love it!
OBJLU
Henry
Los Angeles
2018 JLU Rubicon
I'd go with the 5.13's , it's what I went with and the crawl ratio is amazing. I wheel tons but because if the great crawl ratio I can go easy on the gas pedal which helps avoid breaking things
SteadyC
Chad
Denver
2018 JLS
The math says that 4.88’s are plenty. Three data points, currently running 37’s, if 33’s were stock, and stock gearing is 4.10, then.
37 / 33 = 1.12.
1.12 X 4.10 = 4.6. 4.88’s are the closest thing and a bit bigger.
Here’s a good discussion as well, he went with 4.88’s.
guarnibl
Scottsdale / Sarasota
'21 JLUR 392 XR, '21 JTR, '21 JLR, '09 JK
I blew up my rear D44 (Rubicon) R&P running 5.38's on 37's in my JK. I just threw 37's on my 2.0 JLUR and getting 13-14 mpg because it's never in the right gear anymore (and weight/lift/winch). I probably won't re-gear (as power is fine and it's cheaper to just run some 315's for daily use), but I have heard other folks restoring most of their original gas mileage by swapping to 4.88's. I think over that would be unnecessary unless you are running 40's, which probably isn't ideal on stock axles anyway.
Dogboyslim
Wisconsin
2018 JLU Rubicon Punkn.
Brett
Out of curiosity how are gears 1/2 with this setup? I'm thinking of doing 5.13s also. 1 is pretty low, so I was thinking it may be more a "granny" gear, and I may be able to start off in 2. What is your experience? Thanks!
jlewissystem
J
STL
2019 JLUR MANUAL Mojito!
I run 5.13s in my 6sp as well. I think 1 is usefull depending on the situation. Starting at an incline, i would use 1. Starting at a decline, i could start in 2. For us: my wife has the 2.0, so we havent seen a need to regear on her 37s at all. For my 6sp, i felt is was necessary and 5.13s as Brett mentioned, seem to be perfect so far.
rustyshakelford
Brett
Navasota, TX
I drive slow and don’t get in much of a hurry. From any stand still I start in 1st. I’ll take it to about 10, then run 2nd to 20. Works great. I shift between 2-3k.
I personally won’t start in 2nd unless I’m already rolling. I think you have to slip the clutch more than I like starting from a stop.
Brett
Jammer
Ft worth
Bright white JL Rubicon
488 with 35s that thing must take off like a rocket I'm running 37's with the 410s and have no problems with anything I hit all gears
Jammer
Ft worth
I'm running 37's Cooper SST pros with 410sI have no problems I can go anywhere
and I hit all the gears on the highway
rustyshakelford
Brett
Navasota, TX
Must have the 8 speed?
Brett
