Hmmm... if you want shorter gearing, 4.56 in this case.Is there any reason to pay for the XR package if your intentions are to put a long arm lift with 38-39s. Seems it may just be a waste of money at that point.
You gonna wheel it or just keep it on the street?I wouldn’t be keeping the wheels either as I will be going a bit wider.
Originally I was ordering the XR but now that it’s not available, I just wanted to make sure there wasn’t something else I would be missing.
If you’re wanting range the diesel is a great option. Love my diesel. The 392 isn’t the best if range is an issue. Personally, I don’t think either option will struggle with 40’s. You won’t require regearing with 40’s on the diesel either and there’s tunes out that put torque levels above the 392. Also diesel is close to the same cost as 87 here and I’m getting 22-25 mpg on 37’s with 4 1/2” lift.Being I pretty close to the Rubicon trail. I will be building it for a crawling and overland vehicle.
I’m still even debating the diesel for range and for around the same cost of the 392 I can get the suspension and wheels for the same cost.
I’ve had fast cars. Having a Jeep that does 4 sec 0-60 is cool but I’m more interested in wheeling.
I really just want something with enough power to turn 40s at some point.
Only reason I was asking is I’d be cautious about throwing 40s on a 392 with the stock D44s but to each their own. XR gears will definitely help turning those tires. I’ve got 37s currently on my XR but that’s as big as I’m going until I put bigger axles under it.Being I pretty close to the Rubicon trail. I will be building it for a crawling and overland vehicle.
I think your evaluation is spot on. I'm also running 37" tires on the stock 392 Rubicon axles with 4:56 gears and that's about the max. tire diameter I'm comfortable with. I also purchased (not installed yet) RCV single piece CV shafts for if/when the factory CV's breaks.Only reason I was asking is I’d be cautious about throwing 40s on a 392 with the stock D44s but to each their own. XR gears will definitely help turning those tires. I’ve got 37s currently on my XR but that’s as big as I’m going until I put bigger axles under it.
