392 takeoff suspension on a regular rubicon
GATORB8
CLT NC
21 JLURe
Rubitrux is a forum sponsor, wouldnā€™t hesitate ordering from them.
roaniecowpony
Retired Engineer
Buy what you need. I can find more good deals than I can find money.
PeterKH
PeterKH
Cambodia
Jeep Wrangler Unlimited Willys 2020
Compressed length of the 392 shocks is longer than the stock (non-392) bump stop by about 1/2", making the shock your bump stop if you don't extend the bump. You'd gain about an inch in droop.
If you're looking specifically for Foxes, the 2.0 IFP 0-1.5" would be a better application, maintaining bump stop protection and adding about 2" of shock travel compared to the stock Rubicon shocks.
May i know is the the one 2.0 IFP 0-1.5" ?
Jeep Wrangler JL 392 takeoff suspension on a regular rubicon 1675305448246
mrtm1970
Marshall
Orlando, FL
2019 JL Unlimited Rubicon
Mechanical Engineer
My dilemma is that I just ordered this from Northridge 4X4 before seeing this thread:
Jeep Wrangler JL 392 takeoff suspension on a regular rubicon EB75A4EB-7759-4C98-8968-692FAA688EF4
Do I return them when I get them in? Also not sure if there will be added expense if I return them shipping wise.
I honestly would rather do the 392 set-up as I wouldnā€™t have shock extensions BUT I canā€™t afford keeping the adjustable track bars front & rear and would return the geometry correction bracket and re buy the Mopar LCA (actually had them and returned then via Amazon whenI decided to do this purchase).
GATORB8
CLT NC
21 JLURe
Are you going to wheel it and what tire size are you planning?
mrtm1970
Marshall
Orlando, FL
Mechanical Engineer
I unfortunately will not be wheeling it any time soon and plan to run either 35x12.5/R17 or 315/70R17.
GATORB8
CLT NC
21 JLURe
If you aren't wheeling it, the control arm brackets should get you better steering geometry than LCAs if you are lifting enough to use them.
Realistically, some of the components included in the RC spacer lift are ones you'd want to add (or consider adding) even with the spring/shocks from the 392, and it's competitively priced just for those parts (sway bar end links and bump stops).
Although you can run 35 on road without additional bump stop, you'll want at least some bump extension if you ever take it off road.
mrtm1970
Marshall
Orlando, FL
Mechanical Engineer
Thanks for the input!
I was kinda thinking the same thing and could could recoupe a little $$$ by selling my stock Rubicon shocks and springs but then again, I have almost 48k miles on the stock shocks so probably wonā€™t get much if any for them. And when I have to replace the shocks can go the 392 route.
Ezun
Chad
St. Louis area
And hereā€™s a list of everything included:
  • FOX Shocks front and rear set:
    • 68481296AB, set of two
    • 68481297AB, set of two
  • Front and rear springs set:
    • Rear Spring, 68481302AC
    • Rear Spring, 68481303AB
    • Front Spring, 68481300AE
    • Front Spring, 68547087AA
  • Sway Bar Links:
    • 860AB 1511, set of two
    • 859AB 3560, set of two
  • TrackBars:
    • Rear track bar, P68480854AA
    • Front track bar, P68480849AB
  • Control Arms:
    • Upper Control arm, 68460069AA, set of two
    • Lower Control arm, 68247741AA, set of two
    • Upper Control arm, 68461229AA
    • Upper Control arm, 68461228AA
    • Lower Control arm, 68250242AB, set of two
mrtm1970
Marshall
Orlando, FL
Mechanical Engineer
  • Sway Bar Links:
  • TrackBars:
  • Control Arms:
I would love to get this but no $$$ šŸ˜­šŸ˜­šŸ˜­ Trying to figure out a way to get my 35s :angel::lipssealed:
GATORB8
CLT NC
21 JLURe
Just put them on and stay on the road. You don't have to lift it.
