392 problem
Rubi392
Lonnie
Ferrari 458, panamera 4s Maserati grab tourismo
Seems my 392 is having a problem. After making a sharp turn usually a u-turn I get a sway bar warning light once I shut down the jeep and restart no power steering. Seems like each time this happens the fuse that is tied to the power steering is blown. Once replaced all back to normal... something is not right.
supermike
mike
Irvine CA
18 JLUR 6 speed 2021 JLUR 392
fuse don't burn themselves for no reason...
keep us posted..
Roky
Roky
I want so badly to empathize with you, but right now jealousy is kicking empathy’s ass...?..... I’m not proud of it...... I’ll try again later.....................?
Roky
Roky
Well that didn’t take long, glad to see FCA’s quality control is still setting the bar.
I really don’t mind it...... not having something to fix on my rig scares the crap out of me........ ?
Jebiruph
Jerry
Iowa
2018 JLU, 2020 JT, 2024 WL
I wonder if the heavier front end is taking more force to turn and is causing the electric power steering to pull more amps and blowing the fuse?
Rubi392
Lonnie
first the sway bar light goes on the power steering g goes out after you shut down the car and then restart it. So I think the problem starts with the sway bar electronics
RedundanT
So. Il
2020 JLUR
Stop making U turns ? Sounds like a trip to dealer is in order.
limeade
Guy
Reno, NV
I've read on this fourm where others (non-392 Jeep Rubicons) had similar electronic issues and the problem seemed to be from the wiring harness near the driver side of the front bumper. This harness contained the wiring for the electronic sway bar disco and other things. It was getting worn through from the contact between the lower grille area and frame rail. That's where I'd check first.
Good luck.
