392 Manual Transmission
JEEP4U
Richard
2021 Jeep Wrangler
Any fellow Jeepers running a 392 JLU Manual 5 Spd (Tremec TR-4050)?
blasius01
Cleveland ohio
2022 rubicon 4 door
I wish, thatā€™s the only reason I didnā€™t get a 392, I have to have a manual, not other option to me
Shibadog
Bowling Green, Ky
2020 Wrangler Sport S hardtop
Not from the factory-never offered. Probably ā€˜cause folks would fry the clutch.
JEEP4U
JEEP4U
Richard
2021 Jeep Wrangler
You are correct........This one would be built (non factory)
Jmos4
2020 Challenger Scat Pack M6/2007 Ram 2500 G56
Hi,
Believe more of a emissions deal that wouldn't allow a manual transmission, they are killing them in the Challenger Hellcats, think the 5.7 and 392's you can still order one, but guessing we won't see many in the future.
If they did offer one the older G56 that was offered in the Hemi Ram pickups 2005?/2006 thru 2008 would be fun, creeper gear od 5 speed.
Regards,
2nd 392
Ca
Plus the first standing start dumped clutch would likely grenade the already marginal D-44 and/or other driveline components.
JEEP4U
JEEP4U
Richard
2021 Jeep Wrangler
I agree......would be for D60 or better axles.
Bzinsky
Usa
2022 rubicon 4xe
The rear end is only receiving 50% of the power during a launch
2nd 392
Ca
Heckā€” my 69 GTX had a D60, 95 Ram V10 has a rear D80, front D60 . 470 HP Wrangler gets 44ā€™s, pathetic, not even a D50 upgrade!
Bzinsky
Usa
2022 rubicon 4xe
Not for this build.
Why not? Just keep the awd for the road and use 2wd in the sand/dirtā€¦..Unless there is no way to use the transfer case with the manual trans.
JEEP4U
JEEP4U
Richard
2021 Jeep Wrangler
Stellantis will have to come out with a better axle to add 37" tires as an option.........to match the Bronco
Bzinsky
Usa
2022 rubicon 4xe
Well we do get the same trans as 650hp bmwā€™s.
2nd 392
Ca
When the computer senses rear wheel traction loss and engages the front axle. On a standing start dumped clutch the rear end could likely be toast before the front is engaged .
2nd 392
Ca
Perhaps on a grand finale, swan song, end of an era special edition like all the Challenger/Charger last year ones.šŸ™ Donā€™t hold your breath , Sadly!
