392 includes mandatory Selec-Trac and CV joints. Is this a fatal flaw for anyone?
CivilJeep
Tega Cay, SC
2020 Wrangler Unlimited Sahara
Engineer
aldo98229
Aldo
Bellingham, WA
2018 Jeep Wrangler Unlimited Sahara, 2018 Fiat 124 Spider Abarth
Market Research
I too am very happy with my Selec-Trac. The Jeep feels so much more sure footed.
But, for the record, Selec-Trac does offer a 2WD mode.
All the available modes are:
2H
4H Auto
4H Part-Time
N
4L Part-Time
word302
Oregon
JLU
2H
4H Auto
4H Part-Time
N
4L Part-Time
There are many different iterations of Selec-trac. While I'm not sure what they're calling the system in the hemi, it does not have 2WD.
aus-jeep
NorCal
JKUR
It's interesting to hear that the new 392 Wrangler will only be available with the Selec-Trac transfer case without 2WD, and have CV joints. Personally, I've been very happy with my Selec-Trac system, but have heard from the purists that it's a fatal flaw. Thoughts?
https://www.msn.com/en-us/autos/aut...tty-detail/ar-BB1bhJz0?ocid=spartan-dhp-feeds
I believe we're still waiting for Atlas to get the JL t-cases out to market!
If the CV joints aren't strong enough you can just replace them with RCV's 😎
They are arguably stronger than u-joints, and have other benefits like greater turning angles, and smoother operation when turned.
https://www.rcvperformance.com/ulti...set-for-jeep-wrangler-jl-jt-rubicon-1-pc.html
  • stronger than OEM Dana 60 u-joint axles
  • Axles outboards are gun-drilled with a grease fitting at the end for easy maintenance when needed. No need to remove any parts (but a center cap on the wheel)
  • JL Rubicon Dana 44 axles backed by a limited Lifetime Warranty against breakage up to a 43" tire.
It will be interesting to see if the warranty changes with the 392
At the end of the day it's really not a drama as both u-joints and CV's are good options and it comes down to personal preference.
I'm pretty confident you'll even be able to switch back to u-joints if you really want to
MoparMike
Connecticut
2016 Dodge Challenger Hellcat and a 2017 Jeep Grand Cherokee Trailhawk
THERE WILL BE A 2WD MODE AND THERE WILL BE A FRONT AXLE DISCONNECT.
Willy's Commando
2013 JK Sport, 2009 Challenger R/T, 2019 Dodge Hellcat, 2019 JLU Rubicon
No FAD = fantastic Stronger front axle
HD CV joints instead of u joints = easier turning when locked
Heres one question no one has answered, what happens when you punch/floor it when you are lock in 4H? Do the axles unlock automatically at higher speeds ?
nvabill
Bill
Virginia Beach, Va.
2018 Jeep Wrangler JLU Sahara, C-182 Skylane
This system will be known as Selec-Trac Auto for Rubicon 392. That means it will be in 4H Auto which is 2H until necessary.
But, this photo could be an oversight by Jeep and you are correct, I suspect for liability reasons.
DavidArmen
Hollywood, CA
2021 Red JLUR
According to this photo on the Jeep web sight it does indeed have a 2H mode, notice the paddle shifters in the photo.
I have seen this as well. It is a promotional photograph using a cluster from a regular wrangler or something like that. The 392 is not going to have 2H on the transfer case lever. This is a fact and is not up for debate. The first option will be 4high auto then 4high part time then neutral then 4low.
DavidArmen
Hollywood, CA
2021 Red JLUR
If it is indeed a photograph of a production 392, then my guess would be that the dash will let you know whenever you are in 2 wheel drive or 4 wheel drive (because of 4high auto) depending on which icon is lit up. But you will not be able to have the lever be in 2H because there is going to be no 2H on the tc lever.
CivilJeep
CivilJeep
Tega Cay, SC
Engineer
  • Thread starter
  • Thread Starter
  • #14
THERE WILL NOT BE A 2WD MODE AND THERE WILL BE A FRONT AXLE DISCONNECT.
Why would they use a FAD if there's no 2WD mode? I find this statement to be highly unlikely.
nvabill
Bill
Virginia Beach, Va.
Yeah, I don't doubt that there will be no 2H on the vehicle. By limiting it to 4H auto it will put power to the front axle if the back starts spinning. This will keep the vehicle straight and prevent some bozo from wrecking, can you say LIABILITY! LOL
Motor City Aftermarket
