392 Dealership Programming for 37’s
MORubi
Kansas City MO
2018 Red JLUR, 2014 Jeep Grand Cherokee
Construction
Does anyone know if I can still pay the $125 for my local Jeep dealership to adjust speedometer and transmission for 37’s on my 392 when it finally gets here. Or do I need to use a tazer? Obviously the dealership is cheaper route but I also don’t want to lose my warranty. Thanks y’all!
jludave
The Isle of Long
IT Manager
1st, you won't lose you warranty for using a programmer to change tire size.
2nd, it's been posted on here that most dealerships are no longer doing programming for tire size. Your best bet is to contact your dealer and ask.
Mikester86
2022 JLR
Third, If adding a tire size other than what came from the factory, the dealer could technically void any warranty claim that may heave resulted from said change.
Zandcwhite
Zach
Patterson, ca
2019 jlur
They have to prove that the modification caused the warranty issue, it is far less risk than some make it out to be. We’ve had ours in for the steering box replacement for instance, with 2.5” lift and 37’s without issue. One could try to argue that the change in angles and oversized tires caused the problem, but the tsb and the fact that Jeep went to the steel box on all new models kind of negates that argument. Especially with the availability of the xtreme recon package, they’d be hard pressed to argue that 2” larger tires caused some kind of damage.
Mikester86
2022 JLR
I totally understand. But they can simply say that the mod caused or was a contributing factor and deny it. One would hope common sense would come into play here, but all dealerships are not created equal.
av8or
Randall
Oregon
2020 JLUR, 2023 Rivian R1T
FedEx-retired
I was denied warranty for a worn drag link because of my 37s. I probably could have pushed harder, but I felt like it’s better to let the dealership (Lithia Dodge/Jeep in Medford oregon) show their true colors and pay for an upgrade myself, vs arguing with them only to get a replacement OEM drag link that would wear out in 25k again. That dealship is dead to me now. Moral of the story...........If you want to keep your warranty in tact I think it’s best to never let them see it or document that you have 37s.
Zandcwhite
Zach
Patterson, ca
2019 jlur
The Magnuson-moss act says they can't "simply say" shit. They are required to prove the mod caused damage. Sure if you have a crap dealer you might have to fight, but you'll win
Zandcwhite
Zach
Patterson, ca
2019 jlur
A worn out drag link is a wear item, 25k miles before replacing a part that should be replaced with any lift kit isn't exactly a cause for concern.
SSWIM
Sam
Too Many
Yep and you have to litigate the whole mess. Maybe you have deeper pockets than the Manufacturer but I sure don’t. All they have to do is claim the mod contributed to said failure. They don’t have to prove anything unless it is brought to litigation. Then the fight is on. Legal fees and all.
Sam
av8or
Randall
Oregon
FedEx-retired
Ummm.....a wear item? ........Ok.
Zandcwhite
Zach
Patterson, ca
2019 jlur
Tie rod ends wear out, like brake pads, etc."Parts such as tie-rod ends, wheel bearings, CV joints, U-joints, suspension bushings, and even many engine parts are considered parts that will wear out over time."
MORubi
MORubi
Kansas City MO
Construction
This got hectic fast. So tazer then! Lol!
Multiple places..
MORubi
MORubi
Kansas City MO
Construction
Outrun
PNW
2021 392XR
My dealer will do it and it doesn't void warranty.
