392 Dana 44 axles beefed up for 392?
jessedacri
Jesse
Los Angeles, CA
2019 Bright White 2dr JL Rubicon 3.6
thanks for the clarification. That’s kinda what I meant ... although I wouldn’t use the word ‘symbolically’. the 392 does not have the FAD system at all - it is deleted. But, to your point, the hole in the housing is still there. Not sure it’s weak, though. Weaker than a full tube? I would think .. relative. I’d certainly rather it be a solid tube.
That said, I haven’t researched failures of the housing at the FAD opening. Maybe that’s an issue I’m unaware of???
great to know it is actually a one piece axle and not collared. That was one of the big questions I’d wondered since it was brought up earlier.
This is a case of “ask me how I know” - I bent my JLR’s front axle at the FAD housing and dropped $4600 on a UD44 to avoid it happening again, and I’m only running 35s. It’s a poor design. I ran across someone else in my area who was also seeking a replacement axle for the same reason at the same time, his completely snapped at that area.
The cast FAD housing is the weakest part. You can easily toss upgraded shafts in to eliminate the FAD itself but the housing itself is the weak point. I would at the very least truss it if I were a new Jeep owner.
jessedacri
Jesse
Los Angeles, CA
Seems HD collars just for the FAD housing to axle tubes should/could be offered by after market suppliers.
It's tough - I've seen multiple types of failures, but typically what happens is the cast FAD housing itself comes apart. The spot welds holding the short tubes in fail under heavy load and then start tearing the cast housing. I think the best preventative anyone can do with these is the Artec or Rusty's truss - rusty's especially has a collar type piece in theirs designed to strengthen the fad tube entry (although mine failed more significantly at the *outer* tube and FAD connection):
Jeep Wrangler JL 392 Dana 44 axles beefed up for 392? rc-ramtx4400-jljt-on-axle-greyed-wm-web
Odyssey USA
Daniel
Indiana
www.youtube.com
Sahara
So is the Mojave the same with as a Rubicon or standard with JT or JL?
sourdough
sourdough
left coast
JL
Nice. But welding cold rolled metal to cast metal is out of my comfort zone. Heard to do right you preheat cast metal and cool slowly after welding. Sounds tough to do unless the axle was stripped and on a stand. I'm more of a simple R&R guy now. If itdoesn't bolt it on, it's not going in my cart.
Comac90
Teak
NC
392XR
Out of curiosity, what happened when the housing failed? What kind of terrain, speed, etc?
ascuro
2021 JLUR 392, 1985 CJ7, 1975 CJ5
Someone on here said the front shaft on the FAB side was still collared, but that doesn’t make sense to me.
Unfortunately it looks like it's still collared (around 5:18 in the video).
jessedacri
Jesse
Los Angeles, CA
Not sure about the shafts but the weakest point is still there on the axle housing. The cast FAD housing that interrupts the passenger side tube is where a lot of axle breaks including mine begin. Bummer they don’t offer a regular 3 piece axle housing from the factory anymore.
Comac90
Teak
NC
392XR
i actually saw that same video yesterday. That’s unfortunate.
I read on the the recon thread someone saying they were told the recon pkg comes with a normal front housing. I’ll believe it when I see it, but I actually ordered a 392 today with that pkg — we’ll see.
Gorilla57
Chandler AZ
2019 JLUR Mojito
That guy has no clue how the FAD works......"the regular JL's have a vacuum disconnect for the front driveshaft here". Ummmmmm, it's electronic and disconnects the axle shaft. :headbang:
Cypher
J
AZ
Cybersecurity Leader
He actually made quite a few incorrect statements, not someone I would consider an expert for sure.
Billet Wilson
2017 JKU RHR / 2021 Ruby 392
My understanding is the tube was taken from the Gladiator Mojave which is 10mm thicker.
Jtphoto
Thunder Bay ON
2022 Rubicon Xtreme Recon Granite Crystal
The FAD on the XR HD44 is also heavier then the standard Rubicon. The MC FAD skid will not fit on a Xtreme Recon front D44 FAD.
