forcefedjunkie
Thanks for pics, unfortunately I have neither of these harnesses. Must have been a Monday build
Are you able to follow either harness and get a part number for it? My dealer said they will all have a tag and if there is a part number he can order it.Here you go,
Engine bay, looking straight down side of battery:
Passenger footwell kickplate:
Both should be easily distinguishable as the ends are bundled with electrical tape, not cloth fabric.
This makes no sense at all. Dumb if it's true, but I'd suspect the dealer/rep is grossly misinformed or just making excuses.Update. Dealer says that FCA rep said that the 2021 Wranglers don't come with the harness, just circuits in the PDC. This is to prevent people from adding non-Jeep aftermarket components.
Looks like the harness part number is on the end behind the switch bank. From a sellers' pic, it looks like it's 68321507AC. I don't see it available for sale individually anywhere though, just as the entire switch bank kit.Are you able to follow either harness and get a part number for it? My dealer said they will all have a tag and if there is a part number he can order it.
Had to use a hanger to pull it up enough to cut the first loop of tape w/scissors. You need to dig and surgically cut tape to get to the point where you can hold it in your hand.Here you go,
2021 EcoDiesel built in May and delivered July 7, 2021.
I came to this thread to find my seemingly non-existent underhood aux harness.
FOUND IT! It's very deep (lower than the battery tray), folded over several times and wrapped w/electrical tape. You can see it in the middle of this pic...
It's on the left side of the passenger footwell... look for the electrical tape holding it up.yes, the part in engine bay is definitely exist, however I was saying the one in passenger footwell was missing.
That is incorrect. I have the 2021 and I easily found mine under the hood and in the pax footwell.Update. Dealer says that FCA rep said that the 2021 Wranglers don't come with the harness, just circuits in the PDC.
I have a 2021 and my harnesses are there and found easily as well.That is incorrect. I have the 2021 and I easily found mine under the hood and in the pax footwell.
