The clutch lock disengages at higher speeds for people who forget they left it in 4hi.it was DEFINITELY releasing on me without slipping. I was monitoring the TCase torque lockup and it was going from like 1100ish nm force to zero instantly.
I even drained the case when I got home and there was zero burnt smell and fluid looked new.
I get it, I wouldn’t wait around on a tune either if I needed 4wd at higher speeds.It was disengaging on me at speeds under 30mph, but under heavy throttle/wheel speed. I’ve never paid attention to my speedometer in the dunes when the wheels are spinning. But the jeep should be smart enough to sense wheel speed and NOT disengage 4wd. I’m not willing to fiddle with it and wait for someone to figure out how to out tune the dumb factory transfer case programming. It was also disengaging when using the Tazer to disable traction control. Again, I wasn’t willing to wait for programmers to figure it out.
On top of all the computer issues, there have been documented cases of mechanically failures with them and needing a warranty replacement. Again, not worth the headache to figure out.
I was the first person in the world to have an Atlas in a factory 392 and I’m super happy to have it.
The 392 has different programming than the 4xe for the mp3022. It doesn’t have a 2hi. That is why, IMHO, the 392 is having t-case problems and the 4xe is not. Thus an atlas for the 392…I get it, I wouldn’t wait around on a tune either if I needed 4wd at higher speeds.
Sure enough I googled it and several people with the 392 are having issues. Learn something everyday.The 392 has different programming than the 4xe for the mp3022. It doesn’t have a 2hi. That is why, IMHO, the 392 is having t-case problems and the 4xe is not. Thus an atlas for the 392…
@1996cc ... Crush here Love your build !! Excellent Job !! I just ordered mine from Advanced Adapters .... & I had a couple Q's for you:I did the computer stuff today. And things appear to be working well. I’ve never dealt with the AlphaOBD software and I had no idea what I was doing. I used a Vgate vLinker with cables to plug it into the SGW ports (same place the Tazer plugs in) and connected to that via bluetooth with my Windows laptop. First I unmarried the Tazer (I have no idea if that was needed, but it’s what I did). Once I got the AlphaOBD software to connect to the Jeep, I spent close to 30 minutes fiddling around with the software to try and figure out what I was doing.
Under the “Active Diagnostic” tab, I then selected “Car Configuration Change” and then searched for Transfer Case. That brought up this list of options. I chose 241 (it was set for 246), and just clicked next.
Once I was done, under the main menu, I read the system status (or ID, I can’t remember) again and scrolled down and can see that is shows correctly in there now as well (it showed 246 before)-
Once that was complete, I cycled the ignition and then remarried the Tazer and reconfirmed all my settings there as well as changing the Tcase ratio to 3.030 as directed for the Atlas. I had to clear the fault codes twice and do the two Tazer sleep cycles.
Then I did a short test drive at my house in front wheel drive (I still don’t have a rear driveline). Everything appears to work as designed and there where no weird dash lights when I put it back in the shop
Tom Woods should be calling tomorrow to confirm driveline specs (my old one landed at their shop Saturday), and I’ll likely have it back before the end of the week. Unfortunately (and fortunately), I leave Saturday for a Sprint Break vacation. Hopefully I’ll get to drive it officially before we leave town, I’m definitely anxious to!
One other minor detail I need to finish up is the shifter boot. Advance provides a good option to reuse the factory one, with decent instructions. I still need to do that, but not in a huge rush. (So I won’t have the top stickers on the shift knobs until that’s done.) I’m also waiting on new blocks and barrel nuts for the shift cables from Advance. Mine were not the proper tolerance, but I made them work for now. Once I have those, I will also adjust them to make the shifters line up more evenly.
