39” BFG MTKM3 pic & info request
SolarWizard
San Diego
Nacho3lJT
Owner @ Solar Co
Hi all!
over here from the JT forum but I’m looking for some input on people who’ve run them, what your experience has been, how well they fit stuffed and the absolute minimum backspacing I canuse to run these on rubicon axles. planning to run 8.5” non beadlock wheels to keep the weight down and extend the life of ball joints and unit bearings as long as possible. Planning to run the 3” rockkrawler 4 link X factor lift with non split fenders and yes, even mudflaps
please show me what you’re running. TIA!
SSBattalion
2022 JLUR
You can see the BFG KM3 39's on my rig. Just check it on Instagram: seven_slot_battalion … last post. I'm a Rubi on 3" Rock Krawler myself. Wheels are KMC Machete Beadlocks. Fits fine, no issues.
SolarWizard
SolarWizard
San Diego
Nacho3lJT
Owner @ Solar Co
great page! Did you have split your flares or just a preference?
Gdub
Geoff
Tucson az
2018 JL Sahara
Engineer
Meh.... they are pretty good. I am normally a toyo guy, when I replace them I will prob go back to toyos.
Jeep Wrangler JL 39” BFG MTKM3 pic & info request EB1AE4E1-8893-4C42-A8E4-EABC84280C34
Jeep Wrangler JL 39” BFG MTKM3 pic & info request D8CCB2B1-530E-4661-A254-88F456517E84
SolarWizard
SolarWizard
San Diego
Nacho3lJT
Owner @ Solar Co
Those look different than the roam sliders?
Gdub
Geoff
Tucson az
2018 JL Sahara
Engineer
Why do you prefer Toyo?
I like the look of the toyo MT, the compound seems to be a little harder. Just watching how these are wearing, and I rotate them regularly I don’t think I will get anywhere close to the mileage I get out of the toyos. Tires are all preference. I will say for these being a 39 and on a beadlock, once I got them dialed in they are not noisy and ride nice.
ChattVol
Tennessee
JLU 4 door
Thanks...what about offroading performance vs the toyo? What size toyos did you run and how many miles did you get out of them?
Gdub
Geoff
Tucson az
2018 JL Sahara
Engineer
So that one is tuff for me to answer as I have toyos on my f150 and on my 2018 Sahara, but I only kept the Sahara for about a year before trading it in on my Rubi. I ran 37x13.50 on the Sahara on a 20” rim. On my f150 I get about 70 k miles out of a set, but they are worn out when I get a new set, I run a 33x12.50 on the f150. I am on my third set with 200k on my truck. The truck sees a lot less Offroad than my Jeep so I cannot give a good perspective on Offroad performance.
SolarWizard
SolarWizard
San Diego
Nacho3lJT
Owner @ Solar Co
I like the Toyos but they’re 19lbs more per tire in a 40 or 13lbs in a 38 but that requires an 18” wheel which also weighs more
Gdub
Geoff
Tucson az
2018 JL Sahara
Engineer
I did not focus too much on weight as I knew I was running bead locks, but you make a great point.
HappyJeeper
Eric
San Bernardino Nat'l Forest. Calif.
'20 JLURD, '09 Tundra 5.7 4x4, '21 Prius
Soils engineering/geology
I went with 37" BFG mud terrain and kept them on stock rims. I didn't want the tires sticking out much. I have a 2.5" lift all to keep it fitting in the garage.
SolarWizard
SolarWizard
San Diego
Nacho3lJT
Owner @ Solar Co
oooh I just discovered those LOD sliders. How do you like them so far and did you get the skid?
did you regear?
Ruby Mike
Michael
Southern California
2020 jeep wrangler diesel
did you regear?
I am using Rock Slide Engineering. Except for a hiccup with the actuator bar that bent the slider is great.
