Varilux
- Pete
- Dec 29, 2018
- Hickory Creek, TX
- 2018 Jeep Wrangler Rubicon
- Vehicle Showcase
- 1
After reading through a lot of threads and going back and forth on how to go about swapping up to 37" tires on my 2 door Rubicon, I settled on the following, and am exceptionally happy with the results:
Nitto RidgeGrappler 37x12.5
Teraflex 1.5" spacer lift
Teraflex 2" bump stop kit
KMC XD137 17x9" wheels
MiniTaserJL (to reset tire size)
By staying with a minimal lift, I was able to get the clearance I need to clear the 37" tires (tiny amount of rub when the suspension is fully flexed and the wheel is turned as far as it will go, but nothing major) without having to change from my stock Rubicon shocks and with very minimal change to the driveshaft angle. In fact, the steering wheel didn't even need any adjustment- everything seems just about exactly as it was before the tire and wheel swap.
My goal was to fit 37s with minimal changes to the suspension- but still allow for offroading (I don't rock crawl, but I do hit the trails occasionally). This seems to do the job perfectly. The only thing I may change in the future is to reduce the height of the bump stop- because- based on how far we were able to flex things- it seems like we could go with less without creating contact with the fenders.
The Jeep definitely drives a bit differently with the 37s- the bumps in the road at highway speeds are more noticeable. However, it also feels like the Jeep tracks better. I mean, it bounces around a bit- but it seems to return itself to straight better. Kinda a fun ride (so far) actually!
I haven't made it into 8th gear yet, but the get up and go seems just as good as it was before- definitely not sluggish. I am VERY glad I decided to go 37 instead of 35 (I know I would have immediately regretted going with 35s). The most complicated thing about the install was the need to rip everything apart twice (on the first attempt, we realized my JL was missing the passenger upper coil isolator from the factory)! Glad I have running boards and grab handles (bit more of a step up into the cabin now)!
BEFORE
AFTER
BEFORE
AFTER
