StingGrayRhino
The damn stuff ok things are wayyyyyyyy too thin for any respectable tire. So I'm wondering if I can run these tires on stock rims and safely go off-roading?
Beadlocks?
Beadlocks?
...and what if I have beadlocks? Can I air down to about 10?Can easily run a 12.5 on a stock 7.5 no problem. Just down air down as far. Usually keep my wife’s around 15psi
Oh yah no worries there, probably get it down to the 6 range depending on want your wheeling...and what if I have beadlocks? Can I air down to about 10?
Damn ok. Yeah looking at the Nitto Ridge Grapplers and when you go to their website it shows 9.5" minimum for those tires. I guess they're just covering their ass.No problem with 37" K02s on stock have done some pretty extreme stuff for what you can find in our area. https://www.barnwellmountainra.com
If the 10" is on the left, it sure looks taller than the others.Putting in some taller springs on one friends Jeep and some exhaust work on another, we all run different width wheels but same tire so thought I’d show a neat comparison
10” wide vs 8” vs 7.5”
Narrower the wheel, the tire will pinch in more making it slightly taller so you will need to run a lower daily psi for even tread wear
I run stock KO2s on stock rims down to 17psi, no issues whatsoever.I'm trying to figure out the same question... How low can I go? The pic below is at the full street 36 PSI on my Ironman 35x12.50's, but I'm nervous about how low I can safely drop them. I saw a reply from @stil2low above saying 15 PSI, but since my wheeling involves my entire family of 6 (I have an aftermarket 3rd row seat) in the Jeep, I don't like to push boundaries. Getting stuck would NOT be the business! LOL!
Is 15 PSI conservatively safe? If not, what ballpark should I be in?
15 is a good pressure for a stock width wheel, wheeled lots at that pressure along with many others with no issues of slipping a beadI'm trying to figure out the same question... How low can I go? The pic below is at the full street 36 PSI on my Ironman 35x12.50's, but I'm nervous about how low I can safely drop them. I saw a reply from @stil2low above saying 15 PSI, but since my wheeling involves my entire family of 6 (I have an aftermarket 3rd row seat) in the Jeep, I don't like to push boundaries. Getting stuck would NOT be the business! LOL!
It’s just the way the tire is leaning, it’s actually about a 1/4-3/8 shorter than my 8” wideIf the 10" is on the left, it sure looks taller than the others.
