35s on STOCK wheels NO lift
Dubeau9005
Keith
Ottawa
2018 Jeep Wrangler JLU Sport S, 2010 GMC Sierra 1500
I've had 35/12.50/17R on stock lift and rims for about a month now No problems or rubbing.Eventually ill get a lift but definitely not in rush to do so
Can you please attach a pic of how the tires sit in comparison to edge of fender? Thinking of doing same idea as this on our sport S with factory wheels but curious about how the offset will look. We will most likely be doing a small lift but that won’t change the spacing. Thanks
ATXMTB
Ben
Austin
Ocean Blue JLU Sport S, Red Grand Cherokee Trailhawk
Nitto's website lists their 35s as need at least 8.5in wide wheels. I have the same graphite wheels and I was worried the 35s wouldn't fit since they are 7.5. Any issue with that yet? Also did you put wheel spacers on to give you some more clearance behind the wheel? Thanks
pcpopcorn
Clarkston Mi
2018 JL Rubicon Firecracker Red
35 x 12.5 x 17 Nitto Ridge Grapplers on stock Rubicon JL wheels with no lift or spacers. Runs absolutely fine. No rub and good clearance for city driving.
Can you take a side Profile Pic of your Non Lifted 35s?
I have a 2 door Rubicon and want bigger tires.
I just don't want to go through the pain of 37s ,Lift,Spare Tire Loss of vision in rear window,Weight etc.
sanman357
Carl
L.I. New York
-*|||||||*- 19' Mojito! Rubicon 6-speed, 09' Ram TRX4, 67 Chevelle 300 Deluxe
Maybe these will help. 315/70r17 big k02. Stock wheels no lift or spacers.
MarkA527
Sorrento FL
2019 JLU
I've searched and searched and just can't find this answer.
Just bought a new JL ULS. We want to build but need to do it slow, funds you know. Please don't respond unless you know. THIS IS NOT A RUBI.
Will 35s fit on an unlimited sport with the stock wheels no LIFT? Not trail or climbing.
Please see pics of what I have now. Thank you.
I feel your pain !!! Because all just talks about rubis and what not! Well I finally decided to take the plunge ! Just make sure your offsets are good ! But a simple answer to your question “YES IT WILL FIt” no lift stock JLU Sport S .. very little clearance when you have the wheel fully turned, but it runs the plastic part which I see some people are you able to take it off ! Good luck! I’m currently battling TPMS reading — we put new ones in but it’s not reading — some says to keep driving for it will re learn itself
johnwpowell
Corolla NC
2018 Wrangler Unlimited Sport S
I ended up doing stock rubicon tires on powder coated stock rubicon wheels and couldn’t be happier.
bartscrc
Ryan
Cincinnati, Ohio
Punk'n JLU
heh, hope you never off-road, that’s going to smash the heck out of your paint, hinges and everything.
Haha nope... got a lift kit sitting on top of my stairs that I need to put on when the work schedule lightens up a bit.
Mark7411
Delaware
JL Sport
Are those 35s. I have the sport and want to run the same set up- stock rims with Nittos 315-70-17, the width is 12.70, a little wider than the the 35s. Do you think that will work with 2 inch lift, but I don’t want wheel spacer. I’m having a hard time figuring this out. Not much out there on this setup.
