LKG
This is solid advice! You might apreciate this, years ago I bought a 93 YJ with E rated 265 75 16's. I'm pretty sure I could have run them with the valve stems removed. On one trip I dropped them to around 15-18 psi, I forgot I'd aired down and drove it like that for alomost a month. C rated 32's rode a whole lot better!Your feeling is very accurate, as I'm a huge picture whore. And yeah, I've done a few things since that 315's and no lift pic.
I see you have a Rubicon, so it'll be just fine and will be very capable with 35's. Try to stick with a C-rated tire if possible. The metric equivalent 315/70-17 offers a lot of great options. D's and E's will ride stiffer.
When fully stuffing the rear tires, you might get some light rubbing on the backside of the rear wheelwells. A heat gun and a wet rag can easily remold that hump in the plastic liner, to get it further from the tire.
As far as wear and tear, I wouldn't be concerned. A set of 35's or 315's won't even blip the radar. Get a quality set and have them mounted at a shop that has a Road Force Balancer. That size tire and larger require a more accurate machine than what's typically found in general shops.
