fat_head
So I'm getting around to doing my RCV install. This is the 35 spline version going into a Rubicon axle with the 35 spline ARB locker. A couple things...
I called RCV and he said to use only the included axle seals. The factory ones don't fit because the 35 spline axles are too fat. That makes sense to me. However, he also wasn't very familiar with this setup. So it leaves me with some doubts.
As I understand it, these 2 seals are outboard (correct me if I'm wrong) and sit right behind the orange boot, inside the axle housing. Again, all other oil seals are deleted.
Does this sound right to you guys? I'm find doing it that way, I just want to make 100% sure there isnt some missing inner seals I should be installing.
BTW, this kit came with zero instructions, and there is next to no (almost none at all) information on the 35 spline RCV install on the internet.
These are the two included oil seals
