donmontalvo
Keep in mind Jeep is able to void a warranty if tires bigger than 35” are installed.In my experience, most of the folks installing lift kits are doing so in order to run bigger tires, and the bigger tires go on immediately.
I don’t recall dealer push-back on warranty work requests relating to springs/shocks/control arms — for the reasons you mentioned, and because the OEM versions of those parts are so often replaced by the aftermarket versions in the lift kits, and nobody expects the factory to warranty components the customer bought from TeraFlex (or whoever).
On the other hand, I have seen dealer pushback on steering component replacement because “the lift and big tires subjected the steering components to higher stresses that accelerated wear and induced the steering slop and cause the Jeep to wander”… (even though the same steering problems were being found and repaired on Jeeps of the same year with higher mileage.) That’s just one example. As I said, great dealers don‘t look for ways to dodge warranty claims, but there are some lousy service writers and/or dealers that respond like the example above.
Magnuson-Moss Act puts the burden on Jeep to prove fault.
Trust that simple geometry can easily be used to influence the arbitrator or judge.
