35" and 37" JL pics with lift kit
RebelOffRoad
Evan
22551 Shannon Circle, Lake Forest, CA 92630
www.rebeloffroad.com
2018 Jeep Wrangler JLU / Jeep Wrangler Rubicon 392
Jeep Builder
Irishjl
Pa
2018 JLU Sport
I'm really happy with how mine turned out. :involve:
Sport S
Falken WIldpeak AT3 35x12.50r17
Method NV 17x9
EVO 3.5 inch Stage 1 lift
Metalcloak Front lower control arms
Great looking Jeep
Irishjl
Pa
2018 JLU Sport
3” Fabtech Sport System w/ Stealth shocks, 17” Fuel Anza wheels, 37” Mastercraft MXT Courser tires View attachment 84028
I am thinking of the same lift and tires on a sport soft top. Can you tell me the height to the tallest point. Need to fit in the garage. Thanks
217bazan
Liz
Corpus Christi, Tx
2018 Jeep Wrangler Unlimited Sport JL
How much to the tires protrude from the body? I was hoping it’s around 1” to 1.5”
It’s about 3 1/2”
I was hoping it was less when I ordered the wheels, but it’s a 20x12 with a -44 offset. I thought for a second it would look horrible, but once installed it doesn’t look ugly. (In my opinion)
Hope this helps.
Kata
Kata
It’s about 3 1/2”
Hope this helps.
So for a 1” or 1.5” my offset should be what? I’m trying to figure out when I order my wheels what offset should my wheels be. Thanks in advance
Irishjl
Pa
2018 JLU Sport
I like these best
Looks great. Did this have any clearance issues? I am thinking about RC 2.5” spacer lift and 37” Mastercraft. Want a low stance on the JLU Sport.
km58501
ND
2018 JLR
TX_Ovrlnd
CStat, TX
'22 Zilver JLURD
freethinker
Full stock Rubicon wheel/tire info:
Wheel is 17x7.5 +44mm offset, 6in b/s
Center bore is 71.5mm
Lug thread is m14x1.5
Bolt pattern 5x127 (or 5x5)
Stock tire is LT285/70R17 with a load index of 116Q
For a 1-1.5" poke your offset should be around +47mm to +35mm, it depends on the tires you go with. Those offset measurements were based on a true 37x13.5 tire. The variables you need to continue to weigh against each other are wheel width, offset, and true tire size. Certain lifts require a certain back spacing of wheels to avoid suspension and frame rub.
RUSTYS
Rusty
PA
JLUR
Guitar slinger
I was going to keep 37 on stock wheels with spacer but at the price of the wheels it didnt seem worth it and i didnt want to deal w/ the hassle of getting a shop to mount 12.5" wide on stock wheels. I havent had time to play with pressures yet but most like it will be in the 25-30 psi range.
Yeah I think for me 30 psi will be the sweet spot but I don't have a programmer yet and I think 29-30 psi will pop the air pressure lite.
