35/12.5/17 with lift on Sport Factory Wheels?
1quick1
Moderator
Staff member
Moderator
2018 JLUS
I just got back from having my 2.5" lift and 315/70/17s on stock Rubicon wheels and no rubbing.
LailaiJl
LailaiJl
Laina
Black Jl Sport S
  • Thread starter
  • Thread Starter
  • #17
@Trailjeepin , I have the Sport S wheels the upgraded ones. I think they are the same width though.
@1quick1 YAY!!!!! PICTURES PLEASE!!!!!!!!!!!!
Swanny297
NELA
2018 JL
I am probably going to be purchasing the 2.5 RC kit for now.
We are trying to figure out what the factory offset is for the JL Sport and if with the 2.5 kit we can run our factory wheels with the 35/12.5/17 KO2s we already have. Would we need spacers/different wheels?
Anyone have pictures of this already done?
What offset would I need to run those tires?
I have a skyjacker 2.5” lift on my sport and I am running a Rubicon wheel with 285/75/17 ridge grapplers. I have enough space to run a 35x12.5/17 ridge grappler without spacers with this lift on Rubicon wheels. I wasn’t sure either so I went with the tallest narrowest tire just to be sure. I will go bigger once this set wears out. Another thing to remember is even for the tire I have on it now I had to install a relocation bracket for the spare to eliminate interference with the tire and rear bumper.
LailaiJl
LailaiJl
Laina
Black Jl Sport S
  • Thread starter
  • Thread Starter
  • #22
Thank you!
I'm gonna pull the plug and get the RC budget boost and see what happens! Yay! Thank you for commenting it helps a lot.
LailaiJl
LailaiJl
Laina
Black Jl Sport S
  • Thread starter
  • Thread Starter
  • #23
How do yall feel about the tailgate holding up to the 35s weight?
1quick1
Moderator
Staff member
Moderator
2018 JLUS
By my math mine is:
BFG KO2: 65lbs
Rubicon wheel: 21lbs
RC relocation bracket: 11lbs
So just around or just under 100lbs. Just my opinion but I feel very confident about this holding up fine. Northridge agreed and said they've seen worse on JK's and have them hold.
Swanny297
NELA
2018 JL
My tires are about the same, I have the skyjacker relocation bracket and tail gate saver and I wouldn’t be concerned until you get to a 37” tire
LailaiJl
LailaiJl
Laina
Black Jl Sport S
  • Thread starter
  • Thread Starter
  • #26
Yall are awesome thank you!
Pressurized
Rod
Gilbert, AZ
2012 JKU
By my math mine is:
BFG KO2: 65lbs
This is going to be a problem in my opinion... The JL passenger rear corner is not reinforced the same as the JK was. If you put a JK and JL side by side, open the rear gate and lean on it, the JL body flexes all over the place where the JK does not. You must run the Mopar reinforcement or the risk is very high for damage over time. I believe you will see most aftermarket JL bumpers will include swing mounts for this very reason.
LailaiJl
LailaiJl
Laina
Black Jl Sport S
  • Thread starter
  • Thread Starter
  • #28
BF surprised me with the RC 2.5 lift and Tire Relocation bracket, arrives Tuesday! Hopefully I will be posting pictures Wednesday of everything installed!
LailaiJl
LailaiJl
Laina
Black Jl Sport S
  • Thread starter
  • Thread Starter
  • #29
It worked!!!!! JLU Sport S Rough Country 2.5 lift and 35s (315/70/17 KO2s) with NO SPACERS and STOCK WHEELS!!!! :rock::clap: no rubbing at all! I haven't had a chance to test flex but no rubbing with normal driving. I'm so excited! I will take better pictures soon I was too excited to focus. Also the rough country tire relocation bracket used.
intentsrig
JLU Sporticon
Looks good! I wonder if they would fit with no lift. You’d obviously have no room for flexing but would it clear turning wise?
Just wondering since you still have the same offset wheels but now more fender clearance basically. Probably would have to take off the plastic trim pieces between fender and bumper
Thoughts?
Northridge4x4
