WillyLilley
Brett
NY
2021 Jeep Wrangler Willys Unlimited
Anyone run 325/60/20 on 20x10 -18 offset on a sport with Mopar lift? Any pictures?
Dyolfknip74
Ottawa, Ontario, Canada
2021 JLU Rubicon
RZ.
Doug
Pensacola, FL
2018 3.6 Sport S
Blueprints & Tarot
325/60/20 = 35.4/12.8/20 according to the interwebs i used.
Here's 35/12.5 on 20x10's at -24 offset on sport-width axles:
Jeep Wrangler JL 325/60/20 IMG_1388
1Evil55
here
2018 Sport
This is the only shot I have of mine. -24 offset on a 20x10/35x12.5. Wouldn't do it any other way unless maybe a slightly larger tire if I didn't have to then worry about gearing/axles/driveshafts/etc.
Jeep Wrangler JL 325/60/20 eDG40nr
  • Like
Reactions: RZ.
WillyLilley
WillyLilley
Brett
NY
Do you have issues with rubbing? Do you think the .3” would and -18 offset would cause me issues? Thanks for your response and pictures!
WillyLilley
WillyLilley
Brett
NY
Thank you for the response!
  • Like
Reactions: RZ.
1Evil55
here
2018 Sport
Rubbing never been an issue at all granted, its only mall crawled. I'm probably the wrong guy to ask about a different set fitting properly. Assuming you're Mopar lifted and going with a 35/12.5/20 I doubt you'd have problems.
LOBBS
Kyle
Independence, MO
JLR
Quality Manager in Automotive Aftermarket
Looks like the inboard edge of your wheel will move out 30mm or 1.18" and the outboard edge of your wheel 94mm or 3.7". So, you can take a ruler and press it up against your setup up now and at roughly 3 and 3/4 inches is where you'll poke too.
Jeep Wrangler JL 325/60/20 Screenshot_20220812-092829
WillyLilley
WillyLilley
Brett
NY
thank you for this!!
WillyLilley
WillyLilley
Brett
NY
That’s all I do as well. I think 20s kinda give that assumption!
WillyLilley
WillyLilley
Brett
NY
Thanks for all your input!! Here is the final result! 325/60/20, Mopar Lift, 20x10 -18
Jeep Wrangler JL 325/60/20 B37197C9-794C-4BD4-9267-6EE41B77A73E
