smuddy
i'm with headbarcode. I have a 2018 JLUR with the same tires: 315-70-17 KO2s. I had them on before a lift and had zero issues rubbing on the street with full turns. I have since added a 2" spacer lift and also have no issues and had none other than maybe a little minor rubbing on the inner fender as barcode said. To fix that, you can take a heatgun to the inner fender and push it in and out of reach of the tires.
All this being said, I had wandering issues from the get-go. Did all the recommended potential fixes and nothing really worked. Got a new steering gear box installed (but same part number) and it helped for a while. I then put on the 2" spacer lift. Then, it seemed to slow start getting worse. I then put on some adjustable LCAs and that helped quite a bit but it's still pretty bad. And, once I had the lift on there, the dealer wouldn't diagnose the steering/wandering issue any longer. So, I'm actually removing the lift this weekend and have an appt with the dealer to look at it again. I'll be pushing for the updated steering gear box and updated trackbar and hope it helps. After, i also planning on putting the dynatrac 2" kit on with adjustable LCAs.
You'll have no problems with your stock wheels and the KO2s. Go for it!
