315/70/17 OEM Rubicon Wheels/Mopar 2" Lift Kit on JLUS
sstuner
Ray
Northern Virginia
2018 Jeep JL Sahara
Just installed 315/70/17 BFG "C" on my '18 JLUS using Rubicon takeoffs. With the Mopar 2" lift which yielded 3 1/2 lift. Now my front tire rub the lower control arms at left/right lock. Is there unadjustable lower control arm with more curvature to clear the wider tire. Thanks in advance.
jmcdtucson
Jerel
Tucson, AZ
2018 JLU Sport S
I think you will need wheels with less offset or wheel spacers to fit 315 on a Sport. It looks great BTW.
6th Floor Mule
Keith
Woodstock, GA
2018 JLU Sahara 6MT
Jeep Wrangler JL 315/70/17 OEM Rubicon Wheels/Mopar 2" Lift Kit on JLUS IMG_1440
How much of a rub are we talking about? Have you tried adjusting the steering stops? I was researching this same setup today and ran across your post.
sstuner
sstuner
Ray
Northern Virginia
2018 Jeep JL Sahara
The rub is annoying. I'm aware that the JKs had steering stop (bolts) that can be adjusted, but I'm not aware the JLs have the same setup.
1quick1
Moderator
Moderator
2018 JLUS
I have almost the same setup and I can see the tire rubs the swab bar link slightly but can only tell because of the small corner of paint on the link rubbed off but I can't tell otherwise.
sstuner
sstuner
Ray
Northern Virginia
2018 Jeep JL Sahara
Knowing I didn't want to use wheel spacers on my JLUS, I went this route with these JKS adjustable front lower control arms (JKS 1625). On the OEM unit where the orange plug indicates where the tire rubbed.
Black Jeep Convertible
NYC
www.amazon.com
'19 JLU Sport S 2.0T eTorque
Amazon Influencer 😂
Jeep Wrangler JL 315/70/17 OEM Rubicon Wheels/Mopar 2" Lift Kit on JLUS IMG_1766
you just solved my dilemma on how to fit 35’s on my stock sport wheels because it was either going to be wheel spacers or aftermarket wheel, but I love my sport wheels so much that I powered coated them black
Jeep Wrangler JL 315/70/17 OEM Rubicon Wheels/Mopar 2" Lift Kit on JLUS C6B1CC35-64C8-4B7E-BC83-D651D50FB398
sstuner
sstuner
Ray
Northern Virginia
2018 Jeep JL Sahara
BJC, glad I could help. I'm really satisfied with the install, the ride and most of all the lock-to-lock rubbing is gone. I bought my set off eBay as they were readily available. All the other normal online Jeep stores said they would take 2-weeks or more before I would receive them.
cavguy
Arizona
2020 JLUR
Were you able to mount the 35" spare without issue on your Sport using the stock components?
NYC
www.amazon.com
Amazon Influencer 😂
I was referring to my future 35’s, I’m on 33.8 right now
JLAFAKASI
Lito
Richmond, VA
JlU Sport S 2019
Are you still on the mopar 2 inch lift and stock rubi wheels on 35's?
sstuner
sstuner
Ray
Northern Virginia
2018 Jeep JL Sahara
JLAFAKASI, Yes, on Mopar 2" Lift Kit /Rubi takeoffs with 315/70/17.
NYC
www.amazon.com
Amazon Influencer 😂
sstuner
sstuner
Ray
Northern Virginia
2018 Jeep JL Sahara
There are several online tire calculators out on the web. Punch in the tire #s and see the difference.
