df007
I think this is true to some degree, and might fix most, but I seem to have play in the interface where the spool valve lives, and I have taken apart a AC gearbox with the same issue. I can't get to the area with the play without ruining the box so I have not gone for it yet. I have also read of another forum member with the same issue.Sterring boxes themselves are not broken or bad, just improperly set backlash.
Dealers need to learn how to adjust them, instead of throwing new once untill they find one that was set tight from factory.
Planning to tighten up mine here in a few days myself.
As far as I can tell there are 2-3 interfaces inside the box that can have play:
1. Sector gears (adjustable)
2. Pinion gear to worm screw (where the balls ride)
3. Worm-gear to input shaft (where the spool valve and torque sensor/torsion spring live)
