NovaJeep
- Logan
- Sep 12, 2018
- Nova Scotia, Canada
- 2018 JL Sport S
Hey all - My Jeep (and another one, see below) has been in the shop since Monday afternoon for a series of codes:
on Monday, my Jeep's check engine light started flashing when driving at approximately 80 kph, the stop/ start system was disabled and the engine started bucking and running very rough. The roughness issue seemed to go away at 3000 RPM, so I limped it to the dealer for diagnosis.
On Tuesday another Jeep with nearly identical ODO reading came in to the garage reading the same codes.
The shop foreman has been working with FCA engineering on this one. So far, he's tried:
I'll keep you updated as I learn more, in case anyone out there is having the same issue.
When I get her back I'll ask for the detailed codes and diagnosis procedure and post as well.
- Multiple Cylinder Misfire
- Cam Shaft Timing issue (Can't remember the exact code readout)
- Changing oil and reseting code. After 4 minutes of driving the issue came back
- Inspecting engine and valves
- Inspecting the rocker arms (this is not the rocker arm issue posted elsewhere)
- Checking the electronics
