AndySpill
- Andy
- Oct 24, 2023
- Pittsburgh
- 2018 JL Sahara
...and Foster thus will come out to jump start your JL, stuck on the highway in the worst of places because people couldn't crank after a particularly taxing and early terminated ESS event run on one battery (in a dual AGM battery JL) whose appliances, cold conditions and aging battery found that battery lacking ample charge to crank by the time the vehicle early terminated the ESS event.
Tell me Foster, if ESS is so rather aggressively preemptively disabled in dual AGM battery JLs then why did Stellantis introduce a second battery to run ESS events?...because they had nothing better to do than unnecessarily raise the vehicle's cost with a battery that also raises the maintenance cost of the vehicle in its tendency to cannabolize the main battery?
Bottom line, once the ESS event kicks in, depite all the tests you reference, the factors that dictate its early termination in a one battery situation (in a dual AGM battery JL), may do so after that one battery lacks sufficient cranking power...or it may not. I think people are foolish to chance it.
99.999% of people who disable the ESS battery also dislike ESS events. I strongly encourage people who dislike ESS to yank this battery, and people who want ESS functionality to run with battery that provides dedicated power in these events (exception: the Genesis 3 is fine in its running these events with its two combined larger batteries in parallel.)
Debating the efficacy of running ESS on one battery in these JLs is the ultimate pinhead discourse where the 6 cycle limitation you emphasize misses the real point: that you shouldn't run ESS in the first place in these scenarios.
Let's do a cost benefit analysis here champ, weighing the gas savings of running ESS with one battery over the safety of an engine that is working when you're about the make that left hand turn over the highway at 2am and 15 degrees F outside.
Oh, and by the way, that testing you refer to: prior to cold crank, under the factory setup it is the ESS battery that is tested: which when you yank that battery's connection and pull Fuse 42 now becomes, unknown to the vehicle, the main battery being tested, leading the vehicle to often conclude, falsely, that its running a top of the line ESS charged battery because what really got tested, unknown the vehicle, was a beefier main battery over the disconnected ESS one.
