Jebiruph
You quoted a 3.5 year old post, here's my updated jumpstarting guidance. https://www.jlwranglerforums.com/forum/threads/ess-jumpstarting-main-battery-vs-n1-terminal.87726/
@Jebiruph My understanding from this post is that all the current from a portable battery booster (aka jump starter) can/should go through the aux (aka supplemental) battery. From reading the hundreds (!) of posts generated by your research, I think I saw somewhere else that maybe this is not such a good idea. My jump starter is rated for 1200A peak current and 600 CCA, purchased to supplement a Ford 6.7L dual-battery system, and that seems a bit much for the tiny "Aux14." Not to mention the owner's manual warning above.
Regarding the 3.5 year old post, at that time (and probably still) people were struggling to get jumpstarted before their booster pack drained down. Disconnecting the main battery helped take some of the load off of the booster. With the main battery ground disconnected, you can still connect your booster to the main battery positive terminal and all those amps will go from there to the starter.
If you connect your booster to the N1 terminal which is connected to the aux battery positive, all those starter amps still go to the starter and not into the aux battery, even though they go through wires that are connected to the aux battery positive terminal.
